Thin Spokes
Old Mar 26, 2007 | 08:49 PM
bscottb's Avatar
bscottb
Default Thin Spokes
How do you remove the center caps on thin spokes? I don't see any identations where you would pry them off. Do you have to remove the wheels to remove the center caps? Mine are all loose and rattle. I was wondering if they could be tightened, maybe bending the tabs like on old hubcaps.
Old Mar 26, 2007 | 09:40 PM
Snidley's Avatar
Snidley
I usually just use a screwdriver (flat blade) or 2 and slip them in next to the lugnuts and pry them off. If yours are rattling around already, you might be able to grab them in the rounded parts next to the lugs and pull them off. If you are worried about scratching them, take to lugs off from opposite sides, reach in and pull. They come off pretty easily.
