Power Steering woes
Old Mar 27, 2007 | 05:47 PM
DerekT's Avatar
DerekT
Default Power Steering woes
After driving today, I started to notice a discrete whine. Under inspection I found it to be the power steering, so I looked into the reservoir and noticed it was quite low. But found no leaks or any reason for it to be low, which is good.. So I am hoping to just pour some more fluid in and pray that it is okay. But I need to ask what kind of fluid does it take? I checked the manual and it just said GM of course, but I just change the trans fluid and wonder if that ATF will work for the Z06's? Some power steering units can use ATF and I was wondering if it would work for our cars also. Thanks.
Old Mar 28, 2007 | 04:09 PM
Bull_in_a_china_shop's Avatar
I am replacing my rack and pump due to hi miles and it wearing out. Royal purple offers a nice steering fluid. The oem rebuilt pump i have says DONT USE ATF!! So I hope that helps you. I had oreillys call in the spec to a lubrication approval place to pull any cross referneces but most PS fluids are approved with c5's per them. Check w a chevy dealer for a PN.
Old Mar 29, 2007 | 01:27 AM
Cscokd's Avatar
Cscokd
Power steering fluid doesn't just evaporate, so praying won't fix it...it's leaking somewhere. Be sure to look down below around the steering box and the underside of the pump.
To Power Steering woes
