2nd Gear in an A4
Old Mar 27, 2007 | 06:24 PM
Dirty Howie's Avatar
Dirty Howie
Default 2nd Gear in an A4
I'm having a difference of opinion with another Vette owner.
It is my understanding that if you place the gear selector into 2nd on an A4 tranny C5 that the car will ONLY see second gear.
In other words if you go WOT with selector in 2nd.....car starts in second and redlines to fuel cutoff. The car never sees First or Third gears.
Is this correct??
Are there any exceptions??
DH
Old Mar 27, 2007 | 06:32 PM
bcseitz's Avatar
bcseitz
I thought mine kicked down to first when punching it while in second gear?
In the past, I know various automatics with different brand cars stayed in 2nd when you started off there. Better traction in the snow, mud, that kinda thing.
Sorry Howie, don't know for sure on the A4.
Old Mar 27, 2007 | 06:34 PM
csexton's Avatar
csexton
She stays in 2nd
Chuck
Old Mar 27, 2007 | 07:01 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
It will stay in 2nd if you start out there--However--- this is a progamable thing and it can be changed with a tuner
Old Mar 27, 2007 | 09:11 PM
Rag-Top Rick's Avatar
Rag-Top Rick
Is this correct??
DH
Correct!
Not sure if this can be programmed otherwise!
Charlie did a great job of changing my part throttle shift points up thru the gears in drive. Give him a call.
RTR
Old Mar 27, 2007 | 10:17 PM
yaonttwo's Avatar
yaonttwo
Sir, you are correct.
Old Mar 27, 2007 | 10:38 PM
D_BlueVette's Avatar
D_BlueVette
Originally Posted by csexton
She stays in 2nd
Chuck
Old Mar 28, 2007 | 09:29 AM
chaase's Avatar
chaase
St. Jude Donor '12
Originally Posted by Rag-Top Rick
Correct!
RTR
I don't think it can me programmed out. When I asked the tuner I thought they said it was a mechanical lockout, not a programmed one.
Old Mar 28, 2007 | 10:50 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
It will stay in second.
Try this, drive down the road at 65 MPH and drop the shifter from "D" to "2" and tell me what gear the transmission goes to?
It's the same thing, you select a position and the transmission will go there.
Old Mar 28, 2007 | 12:03 PM
2000BSME's Avatar
2000BSME
the c5 model years are different. My '99 stays in second. There is no "absolute" rule, yes there IS exceptions, but I don't know what model years this pertains to.
Is this correct??
DH
Old Mar 28, 2007 | 03:09 PM
tblu92's Avatar
tblu92
The programming tabes for this in EFILIVE are :
D0913--Max speed before the PCM will force a shift to 2nd when the lever is put in 1st.
D0914---Max speed before the PCM will force a shift to 2nd when the lever is put in 2nd
D0918---Max speed before the PCM will force a shift to 3rd when the lever is put in 1st
Old Mar 28, 2007 | 04:04 PM
tiojames's Avatar
tiojames
It will start off in 2nd and stay there.
Old Mar 28, 2007 | 04:47 PM
Dirty Howie
Thanks for the info. I know you work with EFI but do you think HPT has these tables???
DH
Old Mar 28, 2007 | 06:04 PM
bcseitz's Avatar
bcseitz
Well I tried it, I put gear shift in 2nd and took off fairly hard from a standing start. It did not kick down to first gear.
Funny, the car felt like it had the 2.73's back in there again!
Old Mar 29, 2007 | 10:18 AM
tblu92's Avatar
tblu92
DH
I have no idea if HP has these tables in their tuning
files--They were in the "shift at vehicle speed " section and are listed as "Maual hold gear " tables---upshift There is also the same group listed in Manual hold gear--DOWNSHIFT-- as well. I've nwever fooled with them before as the stk settimgs seem fine--
To 2nd Gear in an A4
