Check Engine Light???
Old Oct 13, 2001 | 08:26 PM
SRitger's Avatar
SRitger
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Default Check Engine Light???
This afternoon, just as I pulled into my parking space at home, the "Check Engine" light came on. I checked the intake, and there doesn't appear to be any loose connections that would cause an air leak. The engine seems to be running just fine. Any ideas what could cause this??? :confused:
Thanks,
Steve
Old Oct 13, 2001 | 08:42 PM
AUandAG's Avatar
AUandAG
Default Re: Check Engine Light??? (SRitger)
Steve,
Please don't take offense as that is not my intention. Did you pull the code(s) on the DIC??? That will tell you the source of the "check engine" light.
Jim
Old Oct 13, 2001 | 09:54 PM
SRitger's Avatar
SRitger
Cruise-In I Veteran
Cruise-In V Veteran
Default Re: Check Engine Light??? (AUandAG)
Steve,
Jim
That was the next thing I was planning to do...can I post the codes here and get a "translation"?
Cheers,
Steve
Old Oct 13, 2001 | 09:59 PM
ScreaminDemon's Avatar
ScreaminDemon
Yes
Old Oct 13, 2001 | 10:14 PM
blkvet's Avatar
blkvet
Default Re: Check Engine Light??? (ScreaminDemon)
I was wondering if someone might help me on this same topic..
id REALLY appreciate a translation on these codes i have..
10-PCM - P0410 HC <- this one i believe is the reason my check engine light is on.
and these are past codes i had.. im wondering if when i reset these if the 'H' goes away.. i would prefer not to keep a record of prior fixes in the computer..
here is what it sez:
A0-LDCM - B2282H, B2284H, V1064H
A1-RDCM - B2283H, B2285H, V1064H
B0-RFA - V1255H, V1096H, V1064H, V1016H
Thanks alot for any help on this! :seeya
[Modified by blkvet, 2:18 AM 10/14/2001]
Old Oct 13, 2001 | 11:04 PM
ScreaminDemon
Default Re: Check Engine Light??? (blkvet)
10 PCM-powertrain cotrol module
PO410-HC(history code)-air system-B
AO-LDCM-left door control module
B2282-battery#1 fault DCM-left
B2284-batery#2 fault DCM-left
A1-RDCM-right door control module
B2283-battery#1 fault DCM-right
B2285-battery#2 fault DCM-right
You can't change a history code just by erasing it. It will correct itself after several cycles after the problem is fixed. Your getting intake codes, left and right door control panel codes, and faulty battery codes. I only have a trouble code list for a 99' which doesn't list any V-codes. I've had my batery, left and right cotrol panels and computer replaced before under warranty. There are several bulitins on these problems. Goodluck. :seeya
Old Oct 13, 2001 | 11:35 PM
blkvet's Avatar
blkvet
your right..
i found an archived topic that had alot of information on this topic..
this is one link to one of them that helped me alot
http://forums.corvetteforum.com/zerothread?id=128689
I had my AIR pump replaced a few months ago.. i suspect thats whats causing the problem again..
Thank alot for all that info ScreaminDemon! :yesnod:
[Modified by blkvet, 3:54 AM 10/14/2001]
Old Oct 15, 2001 | 02:14 PM
SRitger's Avatar
SRitger
Cruise-In I Veteran
Cruise-In V Veteran
Okay, folks...I think I found the problem.
The only current code is a P0410C...looks like the AIR pump. :yesnod:
All the other codes are H codes and are just random communications errors...nothing to worry about.
I guess it's dealer time...I'll have them fix the passenger side window, too, while I'm there. :)
Cheers,
Steve
Old Oct 15, 2001 | 05:48 PM
SRitger's Avatar
SRitger
Cruise-In I Veteran
Cruise-In V Veteran
Well, I cleared the code, and the "Check Engine" light went out. It has stayed off so far. I still gotta get the passenger-side window fixed...it won't go down.
Cheers,
Steve
Old Oct 16, 2001 | 01:15 PM
Chopper Larry's Avatar
Chopper Larry
We get this now and then; usually it's vapor from the fuel cap (not fastened enough, or overfill). It goes away and have noticed any problems. I've maybe noticed this 4 or 5 times in 2 years.
To Check Engine Light???
