Front suspension question
Old Mar 28, 2007 | 12:48 PM
Tx Ray-C5's Avatar
Tx Ray-C5
Default Front suspension question
Okay guys here goes.... I purchased my car used from a guy in Dallas, Texas. He told me someone keyed the car so he had it repainted, ALL LIES !!
Now here's my problem, I've got some creeking and now recently some what sounds like poping from my drivers side front suspension.
I pulled off my wheel and noticed some gouges on the bottom of my lower a-arm.
Could it be my lower ball joint ?
Old Mar 28, 2007 | 02:47 PM
Tx Ray-C5's Avatar
Tx Ray-C5
anyone ?? any clues ??
Old Mar 28, 2007 | 04:16 PM
99FewteRC5's Avatar
99FewteRC5
check the sway bar link nuts, they tend to come loose.
Old Mar 28, 2007 | 05:15 PM
MrPickles's Avatar
0MrPickles
Former Vendor
The marks on the control arms are more than likely from running wider from stock wheels, and pretty much locking the steering wheel either left or right.
The knocking noise could be several things. Sway bar end links ...or shock mounts. Take off the wheel and make sure every bolt is snug.
Old Mar 28, 2007 | 05:34 PM
Tx Ray-C5's Avatar
Tx Ray-C5
But the gouges (marks) are on the bottom, underneith, the lower a-arm. I'm thinking he ran over something or hit something.
There is a very small gap between the ball joint and the a-arm. I'll check everything else though......
Old Mar 28, 2007 | 05:41 PM
dbirdz06's Avatar
dbirdz06
How low is the car? If it's been lowered, check to see if the ride height adjustment bolts have been removed. Mine was like this, and I had a knocking noise as I was backing out and turning at the same time.
Old Mar 29, 2007 | 09:33 AM
Tx Ray-C5's Avatar
Tx Ray-C5
Now you're speaking GREEK to me... where are these bolts ??
Old Mar 29, 2007 | 01:38 PM
dbirdz06's Avatar
dbirdz06
There is a bolt that passes through the leaf spring and contacts the top side of the lower control arm. If it is removed there will be a hole in the leaf spring, but no bolt present. Like this:
This may or may not be your problem, just an idea.
Are you still having the creaking and popping sounds?
Old Mar 30, 2007 | 12:54 AM
Tx Ray-C5's Avatar
Tx Ray-C5
The bolt is in place and yes the sounds are still there. The creaking noise got worse after I lifted the car and put it back on the ground. Now the noise is there ALL the time.
Looks like I'll be spending some time under my car this weekend.
Old Mar 30, 2007 | 09:07 AM
dbirdz06's Avatar
dbirdz06
Hopefully you find out what the problem is! Good luck
Old Mar 30, 2007 | 10:07 AM
striper's Avatar
striper
What you may be experiencing is a noise from the bushing where the top of the shock mounts, not the shock bushings, but the one where the shock mounts. Apparently the bushing dries out and shrinks due to age. The shock becomes loose and makes a knocking noise. Vette Brakes & Products has a urethane repplacement part for this. I just received the parts along with my new Bilsteins I will be installing. I had a similar noise. You'll never find this noise source just jacking up the car.
To Front suspension question
