How to check for thrown codes?
Old Mar 30, 2007 | 09:17 AM
tompugh's Avatar
tompugh
Default How to check for thrown codes?
Hello, I am getting 'service' active handling' message and TC/ABS lights on the instrument panel. Also the TC button will not function. This was my first drive after a long winter's nap. Had to charge the battery to start. Everything was fine when I put her away in Nov. How do I view the error codes to diagnose? Thanks, Tom
Old Mar 30, 2007 | 09:41 AM
cliff_ford's Avatar
cliff_ford
www.stengel.net/diccodes.htm
Old Mar 30, 2007 | 10:21 AM
03QSLVRZ06's Avatar
03QSLVRZ06
Tom:
Out where i used to live (Glen Mills)....
Just hold #4 button in, and hit the #1 button 4 times. This will put you in the mode to look through the codes.
I would reset all of them, sicne you changed out the battery. Then see if they come back. I had about 10 different codes when my battery died and i replaced it. I reset all of the codes and not one has come back yet.
Good luck!
Rick
rickgrebner@comcast.net
Old Mar 30, 2007 | 01:45 PM
randomus's Avatar
randomus
Another source for codes and procedures
http://www.vettefacts.com/C5/DICCodes.aspx
To How to check for thrown codes?
