97 code and ground question
Old Mar 30, 2007 | 09:42 AM
JRODDVETTE's Avatar
JRODDVETTE
Default 97 code and ground question
i have a 97 coupe that threw about a half dozen "abs/traction" warnings last year. but i would shut the car off and restart it and it would be fine. but now this year it did the old "abs/traction & reduced engine power" when the car will barely run.
it did this once and then i cleaned the two ground plugs in the engine compartment behind the headlights. and i started it up and it did it again so i pulled the battery and tray to inspect the wiring harnesses under it and cleaned the ground there at the same time. and i drove it to work today(approx. 15miles) and it's been fine.
i pulled all the codes in the comp. and i was hoping someone could tell me if there is one specific ground i should focus on by looking at the codes stored in the comp.(only one was current P1033)
i appreciate any help you can give.
-jared
Power train Control Module (PCM)-
P1033 H C - Heated Oxygen Sensor (HO2S) Slow Response Bank 1 Sensor 1,
P1432H - Fuel Level Sensor 2 Low Voltage,
P1516H - Command vs Actual Throttle Position Performance (TAC Module)
Traction Control System (TCS)-
C1226H - LF Excessive Wheel Speed Variation,
C1278H - TCS Temporarily Inhibited By PCM
Real Time Damping (RTD)-
Body Control Module (BCM)-
Instrument Panel Cluster (IPC)-
Radio- U1016H
Heating-ventilation-air conditioning (HVAC)-
Left Door Control Module (LDCM)-
B2252H - Key Cylinder Switch Fault,
B2282H - Battery #1 Fault,
B2284H - Battery #2 Fault,
U1255H - Serial Data Line Malfunction,
U1064H - Loss of Communications with BCM,
U1016H - ?,
U1096H - Loss of Communications with IPC
Right Door Control Module (RDCM)-
B2283H - Battery #1 Fault,
B2285H - Battery #2 Fault,
U1016H - ?,
Seat Control Module (SCM)- NO COMM.
Remote Function Actuation (RFA)-
Old Apr 2, 2007 | 08:34 AM
JRODDVETTE's Avatar
JRODDVETTE
anyone have an idea which ground is the culprit?
