Lingenfelter has a replacement Walbro pump, goes in the tank just like OEM. Or you could rig up an inline pump between the OEM pump and the filter (which is also your pressure regulator).
You can get as creative as you want, but using the Lingenfelter is the easiest, cleanest way to do it.
