Disconnected Battery - Do I need to reload powerloader?
Old Oct 14, 2001 | 12:20 PM
sbkim's Avatar
sbkim
Default Disconnected Battery - Do I need to reload powerloader?
I decided to "clear" out my pcm my leaving the battery disconnected for about 12 + hrs. Do I need to reload my powerloader or is that not lost during power loss.
Thanks!
Old Oct 14, 2001 | 01:47 PM
RG in Dallas's Avatar
RG in Dallas
Elite Member
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Default Re: Disconnected Battery - Do I need to reload powerloader? (sbkim)
No, it's not lost, nor would a stock program be lost after a new battery nor a drained battery nor a disconnect for that period of itme.
RG
Old Oct 14, 2001 | 05:08 PM
sbkim's Avatar
sbkim
Default Re: Disconnected Battery - Do I need to reload powerloader? (RG in Dallas)
RG,
Man, you are just filled with my answers! Thanks bud! :seeya
Old Oct 15, 2001 | 09:55 AM
C5NBM's Avatar
C5NBM
Is it necessary to clear the PCM once in awhile?
Old Oct 15, 2001 | 10:09 AM
chuckster's Avatar
chuckster
Default Re: Disconnected Battery - Do I need to reload powerloader? (C5NBM)
Naw...Just check your codes once in a while.
If the PCM code were designed by Microsoft there'd be a Ctl, ALT, Del button on the Dash board. :D :D
Old Oct 15, 2001 | 04:22 PM
wwashing's Avatar
wwashing
SB, you should always disconnect your battery at the negative terminal first!
Old Oct 15, 2001 | 04:32 PM
sbkim's Avatar
sbkim
Default Re: Disconnected Battery - Do I need to reload powerloader? (wwashing)
UH-OH! I simply disconnected the B+... The car runs really good now so I guess there is nothing wrong. At least for now...
To Disconnected Battery - Do I need to reload powerloader?
