Removing the plastic valley cover
Old Mar 31, 2007 | 10:58 AM
RSchleder's Avatar
RSchleder
Default Removing the plastic valley cover
I know this is a very basic quesion but I don't want to break the tabs on the valley cover. Do I just grab each end of the cover and tug upward to snap it off or is there another place to pull up or a different procedure I should use? Thanks in advance, Ron
Old Mar 31, 2007 | 11:12 AM
RED99's Avatar
RED99
I have never seen a plastic valley cover. Do you have a pic?
Old Mar 31, 2007 | 11:50 AM
RSchleder's Avatar
RSchleder
Default "valley cover"
Perhaps I used the incorrect terminology- it's the black plastic flat cover that is covering the valve covers/injectors. I want to remove it to install a catch can. Thanks, Ron
Old Mar 31, 2007 | 12:02 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
You mean the fuel rail cover.
There are 2 clips on top, and 2 on the bottom. Unsnaps rather easily, simply pull it away from the engine, you won't break them.
To Removing the plastic valley cover
