Please Help-Installing C6 Z06 Shocks in C5!
Old Mar 31, 2007 | 01:13 PM
Tiger 650's Avatar
Tiger 650
Default Please Help-Installing C6 Z06 Shocks in C5!
I just bought a set of C6 z06 shocks from Gene Culley and I think I have a problem installing the rears. The top mounting plate of the NEW shock is slightly slanted, while my OEM C5 shock plate is flat at the top. As a result one of the top holes fits flush, while the other hole has a 1/4" gap between the plate and the mounting surface. By jacking up the suspension it closes the gap up some and it looks like I will be able to get the other bolt in, but does is this okay? Or, should I call Gene to return the shocks?
Any help would be greatly appreciated.
Thanks,
Bob
P.S. If this is okay, which way should the slant be facing? To the front or back?
Old Mar 31, 2007 | 02:13 PM
yaonttwo's Avatar
yaonttwo
The shocks will work and they are a great improvement over the stock ones. I had the same concern when installing mine. Do not remember which way the slant goes, but it does mate with the holes when expanded. The slant should be on a slight angle which follows the contour of the attachment plate.
Hope this helps.
Old Mar 31, 2007 | 02:16 PM
JeffC5's Avatar
JeffC5
From: Edmond, OK...One of the first rules of online forums: If you don't like what is said but can't refute it, attack the poster.
LOL, I had the exact same worry when installing mine. If you'll turn the top around and try it both ways, you'll see one way matches the contour of the plate. Install it that way. Tightning the bolts will make it all good.
ps, you're going to love the way it handles!
jeff
Old Mar 31, 2007 | 04:33 PM
Tiger 650's Avatar
Tiger 650
Thanks for you help. I got it done and took a test ride. What a difference!! No more second bounce when going over bumps and bridge seams. Very nice handling and kept a comfortable ride!!
Bob
Old Mar 31, 2007 | 06:35 PM
2000BSME's Avatar
2000BSME
Bob
hey, what are you talking about!! Second bounce, that sounds like mine with '04 z06 shocks! Is that what you are comparing to?
thanks
Old Mar 31, 2007 | 07:37 PM
HollywoodFRC's Avatar
HollywoodFRC
Default Me too!
Same issues when installing. Got them in using a jack to get the gap closed in the rears. Hnadles beautifully. 10,000 miles since swapped. Love them!
Old Mar 31, 2007 | 07:58 PM
Tiger 650's Avatar
Tiger 650
thanks
They are '07 Z06 shocks.
Old Mar 31, 2007 | 09:12 PM
2000BSME's Avatar
2000BSME
I was asking what your reference was to... like "what were your old shocks, the ones that gave you the double bounce?" My '04 z06 shocks double bounce on some spots, I was wondering what kind you had that double bounced.
Old Mar 31, 2007 | 09:38 PM
Tiger 650's Avatar
Tiger 650
They were OEM stock C5 shocks replaced with 07 Z06.
To Please Help-Installing C6 Z06 Shocks in C5!
