One headlight doesn't come up
Old Apr 1, 2007 | 08:34 AM
TomT's Avatar
TomT
Default One headlight doesn't come up
Every once in a while, the left headlight doesn't come up. After turning off and retrying, they both come up. Most of the time, everything is fine. I don't hear any noises and I have changed to the metal gears. Any ideas?
Thanks.
Old Apr 1, 2007 | 10:44 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
There are relays in the engine compartment fuse block that the headlamp motor controls go through for each headlamp. You might look there otherwise the headlamp control module itself could be a problem. Its mounted on the right frame rail behind the right headlamp.
