A/C not working
Old Apr 1, 2007 | 12:42 PM
ettev99's Avatar
ettev99
Default A/C not working
Where is the best place to start troubleshooting, should i have 12v at the green wirw near the compressor if not what is the logical next step
Old Apr 1, 2007 | 12:54 PM
fsuforever's Avatar
fsuforever
not to be sounding l;ike a smart a$$ ,but did you check your ac belt ?
Old Apr 1, 2007 | 02:14 PM
IFLUBYU's Avatar
IFLUBYU
first question is your heat and defrost working? If yes skip to 3.
1. Your HVAC compressor is driven by a seperate belt off the crank pulley, so make sure that belt is there and snug, it has a seperate tensioner from the other belt.
2. The compressor end of the belt has a clutch that engages/disengages from the compressor. When you have the HVAC turned on look to make sure it is engaged and turning the compressor.
3. If it is engaging best to take it to someone who has some refrigerant and the correct gauges to see if it will take a charge.
4. if it won't take a charge, one easy thing you can do is check/replace the orifice tube. This catches small bits as they pass through the system and can get clogged up. Have a new one handy ($8), use the shop manual, but dont have the system open for long, and try a recharge after you are done.
5. Beyond that, take it to a professional you trust not to screw you over.
Hope that helps... Good Luck!
Old Apr 1, 2007 | 02:43 PM
ettev99's Avatar
ettev99
Thanks i check belt it's the clutch not engaging i jump 12v to tne motor and the clutch engage i suspect a relay somewhere. The little light comes on inside but nothing hapen i found a blown fuse replaced it still nothing
To A/C not working
