Charge System Fault?
Old Apr 1, 2007 | 01:03 PM
97Rob's Avatar
97Rob
Default Charge System Fault?
My diagnostics screen is flashing Charge System Fault. I have replaced the battery and the alternator. The original alternator was charging 12.9 at its peak. The new alternator charges at around 13.1-13.6. We have checked the grounds. Any other ideas?
Old Apr 1, 2007 | 01:22 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Do you have any aftermarket audio/video installed? Try the big 3 upgrade. Can be done for under $20 and about 1 hour of tme.
Old Apr 1, 2007 | 01:30 PM
97Rob's Avatar
97Rob
What is the big 3? I do have audio upgrades plus electric cut outs. I think the flash happened after the cut outs were installed.
Old Apr 1, 2007 | 03:09 PM
screw991le's Avatar
screw991le
Here is an overview of audio FAQ is HERE
It makes your stock electrical system work more efficiently.
Old Apr 1, 2007 | 08:41 PM
97Rob's Avatar
97Rob
Any other thoughts on this?
Old Apr 1, 2007 | 09:13 PM
JagTech's Avatar
JagTech
Do you have an underdrive pulley?
Old Apr 1, 2007 | 09:24 PM
97Rob's Avatar
97Rob
Yes! Perhaps I would need an over sized pully for the alternator.
Old Apr 1, 2007 | 09:27 PM
berryj's Avatar
berryj
Here's some info which might help:
http://forums.corvetteforum.com/show....php?t=1530169
Old Apr 1, 2007 | 09:38 PM
97Rob's Avatar
97Rob
Thanks! I'll pass this info. on to the tech.
Old Apr 1, 2007 | 10:09 PM
willyfastz's Avatar
willyfastz
I think he just read it
Old Apr 2, 2007 | 11:56 AM
jo8243's Avatar
jo8243
Check the positive terminal connection at the starter (under passenger side header). I had the same problems and mine looked like this:
Old Apr 2, 2007 | 01:37 PM
97Rob's Avatar
97Rob
We had the engine out Sunday fixing an oil leak. The starter and its connections looked good. Thanks for the input.
Old Apr 2, 2007 | 07:31 PM
jo8243's Avatar
jo8243
Where was the oil leak (out of curiousity)? I have one myself.
Old Apr 2, 2007 | 07:37 PM
pdd000's Avatar
pdd000
c5's are very picky on which alt you use. id do a search on the subject
Old Apr 2, 2007 | 08:25 PM
mcgilles's Avatar
mcgilles
I have received this warning twice after starting my car in the last 3 month's I've owned it. Each time the voltmeter actually showed a slight over volt (15+) but not high enough to hurt anything. the battery needed replacing anyway so I did that. No problems since then but I'm not sure if its related.
Old Jun 24, 2007 | 02:50 PM
IrishEd's Avatar
IrishEd
After letting my car sit for a week I disconnected my 1.5 amp battery tender which showed a full charge. Upon starting , I got the infamous Charge System Fault which disappeared and has not resurfaced. No prior problems, the battery is the original, 2004 C5.
Could I have overcharged the battery? Shows 13.8 volts while driving.
Any comments or opinions will be appreciated.
To Charge System Fault?
