Line lock Question
Old Apr 1, 2007 | 09:24 PM
Carz4Toyz's Avatar
Carz4Toyz
Default Line lock Question
Hurst Roll Controll is what it's called actually. Is there a problem putting this on my'98? What about ABS? Where is the best mounting point? Which line to hook into? I installed this on my Viper without any issues but it is a '94.(no abs no technology at all) It was easy, I just dont want to screw up something here. Thanks.
Steve www.crazy4carz.com
Old Apr 1, 2007 | 09:35 PM
ABNVET.I's Avatar
ABNVET.I
I used the hurst and had no issues putting it in. It does not affect the ABS. I made a stainless plate and mounted it under my brake booster. I mounted the switch in the traction control panel. It just takes time and when you buy the tubing to bend get plenty I ruined a few feet before I got it right.
Old Apr 1, 2007 | 09:44 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
Your fine to use it I have the TCI unit, but they are basicly the same and work well.
Old Apr 1, 2007 | 11:14 PM
Irish Whiskey's Avatar
Irish Whiskey
These things are fun!!!! Had installer do mine while he was doing some other work on the car = I have my switch on the left side of steering wheel =can hold in on easily while warming up the tires - mine is A4 with Yank SS3600
Old Apr 2, 2007 | 08:30 AM
Ohiostatefan's Avatar
Ohiostatefan
http://forums.corvetteforum.com/show....php?t=1662500
check this thread out.
Old Apr 2, 2007 | 09:19 AM
Carz4Toyz's Avatar
Carz4Toyz
On the mastercylinder, which is the front brake line. closer to the firewall or closer to the front of the car?
Old Apr 2, 2007 | 09:31 AM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Front is closer to the firewall
Old Apr 2, 2007 | 10:37 AM
Julian@Cartek's Avatar
Julian@Cartek
What year is your car? The line changes dependent on year and type of brake line from master cylinder to abs module (one piece or two piece).
Old Apr 2, 2007 | 11:04 AM
Carz4Toyz's Avatar
Carz4Toyz
'98
Old Apr 2, 2007 | 11:27 AM
Julian@Cartek
On your 98 is the ABS module in the front or the back?
Old Apr 3, 2007 | 07:33 AM
Carz4Toyz's Avatar
Carz4Toyz
I don't know, how do I tell?
Old Apr 3, 2007 | 10:43 AM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
Follow the brake lines from the fluid reservoir -- do they go underneath the alternator to the front of the car into a unit with other brake lines going into it (sitting right in front of the alternator and power steering pump)?
Old Apr 3, 2007 | 12:11 PM
Julian@Cartek
Yes, where those brake lines come together is the ABS module. This is what you are looking for…on all 97 models and some earlier 98 models had this Distribution box by the rear end.
Old Apr 3, 2007 | 01:13 PM
JuicedVette036's Avatar
JuicedVette036
what is the part number for the hurst roll control?
To Line lock Question
