I'm getting ready to install 04 Z06 swaybars, front and rear, on my 97. Are the metal endlinks the same for front and rear? Just checking before I order.
I'm getting ready to install 04 Z05 swaybars, front and rear, on my 97. Are the metal endlinks the same for front and rear? Just checking before I order.
I'll be completing the front and rear sway bar swap on my '00 coupe this week as well. Only I'm installing Z06 sway bars, not the hard to find Z05 bars............just kidding, couldn't resist.
Guess I need to take a typing class! You are right, they are hard to find!
do a search on the install and how you need some dialetric gresse on the bushings and use washers. I need to use that greese as i used lithuim and it didnt work, they make noise and squeek
Make sure you really torque the end links... my Hotchkis rear bar is clunking with my test drive Saturday... I have heard that loose (or not tight enough) end links cause this issue.
geez im a bad speller lol typo master!!!
Suggest you go to Auto Zone, or similar parts store and buy some special grease sold by Energy Suspension, which is made to be used on sway bar bushings........it's great stuff to use and does the trick.
Pick up some polyurethane bushings for the sways too, 30mm front and 23.6mm rear.
Grease every point on the bushing that has a contact point (inside the tube and between bushing and bracket), dont forget the back of it where it contacts the crossmember.
Mine handles like on rails and doesn't make a peep, don't need washers.
Reason: oops
The washers worked for me. Eliminated the squeek. You'll need 4 washers, place them betewen the brackets and where they bolt to the suspension.
I used di-electric grease, got it at auto-zone.
Good luck and enjoy the new handling.
