check engine light and codes.....
Old Apr 2, 2007 | 10:32 AM
02gt350's Avatar
02gt350
Default check engine light and codes.....
So cruising in 6th gear today at low RPM I had a check engine light come on.. Since the header install and tune, this is the second time its done it. I got to work and checked the codes....It said one for PCM and 3 for Radio????? whats that mean?
I cleared them and went back to my fuel gauge. It showed the average reset itself and the range said low...I hada 3/4 of a tank left....any ideas???????
Old Apr 2, 2007 | 01:25 PM
02gt350's Avatar
02gt350
ttt
Old Apr 3, 2007 | 11:41 PM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
You need to dig a little deeper and determine which specific codes are present...not just erase them en-masse. See here for instructions (last paragraph, in particular). The PCM code is responsible for the CEL.
Old Apr 4, 2007 | 07:14 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
You didn't do something right, follow his link to look at the codes.
BTW - I'm sure you realize the 1 PCM code is what caused your "check engine" light to come on.
To check engine light and codes.....
