Shock replacement
Old Apr 3, 2007 | 12:45 PM
Mikev078's Avatar
Mikev078
Default Shock replacement
I currently have the F55 suspension and all 4 shocks are leaking. I looked at replacements & I really don't want to spend $4000 on shocks. I've heard people mention going to Bilstein Sports. When I tried searching for some, they specifically say not for F45/F55 setups.
What other options are there?
Thanks!
Old Apr 3, 2007 | 01:03 PM
FRCTony's Avatar
FRCTony
Thanks!
Search is your friend...
Any C5 shock will work. You must: 1. Have F55 option deprogrammed or 2. Buy sims that plug in and fake out the system or 3. Make your own sims.
Old Apr 3, 2007 | 01:24 PM
Mikev078's Avatar
Mikev078
Ah, ok. Looks like I'll be getting some sim caps then. Thanks a bunch
Old Apr 3, 2007 | 02:26 PM
Sully1882's Avatar
Sully1882
yes, sims and any other C5 shocks will work for you. Might try the 04 Z06 shocks.....i did this on mine and have been very happy...
hth,
Sully
Old Apr 3, 2007 | 07:10 PM
BlackZ06's Avatar
BlackZ06
Thanks!
$4k... where are you shopping ??? Try either
www.gmpartsdirect.com
or www.gmpartshouse.com
You should easily find all 4 for under $2,000.00
I believe the GM part numbers (but confirm this, this is from old notes) are:
Each front shock is number 88952524
The rear are Left/Right 22064827 and 22064828
HTH
To Shock replacement
