headers GOOD BAD THE UGLY
Old Apr 4, 2007 | 09:12 AM
road pilot's Avatar
road pilot
2016 C5 of Year Finalist
Default headers GOOD BAD THE UGLY
Friends
I am going to have a tune and headers installed later this month.Got to
thinking about the headers and wonder 1-will they devalue the cars
worth and 2-will I start having code problems and/or any new problems?
I appreciate your imput.
Road Pilot
Old Apr 4, 2007 | 09:17 AM
DPG's Avatar
DPG
St. Jude Donor '06
When you go get a tune after the header install just have the rear o2s deleted. I went through 2 sets of simulators in a year. I said screw it and got a tune. Definitely worth it. The rear o2s were the only codes i got. Gone now after the tune and some will tell you that you will not pass emissions after tunning out the rear o2s. Not true. Mine passed Also depends on where you live and if they do visual inspections.
Old Apr 4, 2007 | 09:24 AM
STLKillerC5's Avatar
STLKillerC5
Is the car stock? If so, don't waste money on a tune. Your added gains are going to be minimal with a tune, compared to the money you'll be spending on a tune.
You shouldn't have problems passing emissions tests. If you do have a problem a tune will fix it. It's the visual inspection where they sometimes get people.
Old Apr 4, 2007 | 09:33 AM
LightFighter_GXP's Avatar
LightFighter_GXP
the tune is worth around 20 hp and the headers should be worth around 20, so you should seem some gains around 40-50 with both
Old Apr 4, 2007 | 10:52 AM
BitViper's Avatar
BitViper
[QUOTE=STLKillerC5;1559667120]Is the car stock? If so, don't waste money on a tune. ......
You shouldn't have problems passing emissions tests. If you do have a problem a tune will fix it. ....[QUOTE]
With this logic Id just get the tune...think of it as "Optimization" of the system..but it will add what 400 bucks or so to your overalll output of $$
Old Apr 4, 2007 | 11:06 AM
_Will_'s Avatar
_Will_
From: Somewhere between mild insanity and complete psychosis
Headers won't affect the car's value. Most dealerships would be too stupid to notice f you ever traded in. The only warranty issue will be parts behind the headers, which i'm assuming none are stock anymore anyway.
Old Apr 4, 2007 | 11:34 AM
FASST LN's Avatar
FASST LN
Based on experience with headers from my LS1 '98 Camaro:
They hung lower than the rest of the car and would scrape going over some speed bumps and curbs.
They are louder, which could be good or bad.
Picked up noticeable low end torque.
If you're installing them yourself, be prepared, no exhaust fits like it is supposed to.
I had several leaks in mine, which probably wouldn't have been an issue if the connecting pieces were welded instead of clamped (FLP coated headers).
When getting out of the car, you could feel the heat pooring out from under the door.
Really cleaned up the sound of the car, increased the base and made the overall sound more 'mean'.
Old Apr 4, 2007 | 01:01 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
and a lot depends on your state emissions regulations, every state may be different. In IL, they plug into your computer (OBDII), so long as you have no codes present, you pass, there is no visual inspection. So in IL, we just have the rear O2's shut off by a professional tuner, and wala, issue solved. Any of these brand headers are a good choice: LG, Dynatech Supermaxx, Kooks, American Racing. If you are planning on future mods to the car after the headers, I would wait on getting a tune, as you willl have to re-tune again for the new mods...otherwise to take full advantage of the headers a tune is a good idea.
Old Apr 4, 2007 | 01:04 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
Not flaming you , but the C5 exauhst set up is not the same as on an F-boyd camaro, different set up stock, and aftermarket parts are different as well. Not an apples to apples comparison.
Old Apr 4, 2007 | 01:20 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
yes, but its more for a better running engine. The factory tune tends to lean out after installing headers. Plus the stock tune is way too conservative.
Old Apr 4, 2007 | 01:34 PM
Navsafe's Avatar
Navsafe
Headers and a tune. . . I guarentee will put a smile on your face. One of my finest mods and in my humble opinion well worth the cost.
Old Apr 4, 2007 | 02:15 PM
LightFighter_GXP
just save your factory exhaust, you could always demod and sell the headers for a few bucks less than what you paid for them
Old Apr 4, 2007 | 03:50 PM
DPG's Avatar
DPG
St. Jude Donor '06
i would definitely get a tune after headers and an intake. Not only did it liven the car up even more then headers alone, i also get 2-3mpg better avgs and the codes are gone.
Now if you plan on doing more mods in the near near future, then I would wait. If these are the only things you are going to do for awhile, then a tune afterwards is worth it.
Old Apr 4, 2007 | 04:28 PM
Navsafe's Avatar
Navsafe
Also, sometimes you can do the tune and then if you further mod the vehicle and some tuners will give you a deep discount on a follow up tune.
Old Apr 4, 2007 | 06:00 PM
road pilot's Avatar
road pilot
Default headers Good Bad and UGLY
Forum Members
Many thanks to all who responded to my questions concerning tune
and headers. I'm not a green pea; just ol' school and computers in cars
has meant that I am in a learning curve( as far as mods are concerned)
thanks again----Road Pilot
Old Apr 5, 2007 | 12:57 AM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
FWIW On the rear O2s. I added bungs to my Highflow Cats, which I have bolted right unto my Header collectors, zero codes and no short lived sims to worry about.
FYI Some third party testing showed no significant HP loss with Highflow Cats...
To headers GOOD BAD THE UGLY
