Need help with squeaky suspension (T1 BARS) !!!!!!
Old Oct 15, 2001 | 01:37 AM
OliverM5's Avatar
OliverM5
Active Streak: 90 Days
Default Need help with squeaky suspension (T1 BARS) !!!!!!
Since I put on the T1 bars, my car squeaks over bumps. I figured it was the poly bushings holding the sway bars and took a can of WD 40 and sprayed a little on them.......now it sounds like there is an orchestra under my car!!!! Why would the lube make them louder??? It is annoying and embarrassing!! Anyone have suggestions for a fix???
Old Oct 15, 2001 | 01:42 AM
christian_rolland's Avatar
christian_rolland
Default Re: Need help with squeaky suspension (T1 BARS) !!!!!! (OliverM5)
Check the torque settings on the bolts. That normally fixes the problem. This seems to be very common problem after swaybar/endlink replacement.
cr
Old Oct 15, 2001 | 12:48 PM
OliverM5's Avatar
OliverM5
TTT
Old Oct 15, 2001 | 12:55 PM
MattG's Avatar
MattG
Cruise-In I, II, III, IV & V Veteran
CI-I & II Auto-X Champ
Default Re: Need help with squeaky suspension (OliverM5)
Everybody I know that has run these bars has complained about the noise from them. I guess it is just one of them things you have to live with if you want the stiff race-like ride quality of the t1 setup.
Old Oct 15, 2001 | 09:31 PM
Slammed Vette's Avatar
Slammed Vette
Cruise-In II Veteran
Cruise-In III Veteran
The only noise I had with mine were the end links hittting the sway bar and the sway bar hitting the lower control arm.I replaced the the end links with the solid metal ones and they are fine now.
Old Oct 16, 2001 | 12:25 AM
alan33's Avatar
alan33
Oliver:
Basic question: Did you use the Sticky Teflon Grease that should have come with the polyurthane bushings? Sorry, but had to ask. The "special" grease should prevent the squeaking if you put it on thick in the bushings prior to install. WD40 is a cleaner/penetrating oil that will disolve greases and compound your squeak problem. Get some of the Polyurthene bushing grease, take the sway bar out of the bushings, goo the he!! out of them with the grease and reinstall. Large swaybars have a tendency to want to bind and squeak even with the grease. Make sure that the bushings are completely closed around the sway bar and centered in the bushing retaining clamps.
Take Care,
Alan
To Need help with squeaky suspension (T1 BARS) !!!!!!
