AC Problem
Old Apr 4, 2007 | 06:21 PM
Bfail's Avatar
Bfail
Default AC Problem
When I turn my Air Conditioning sometimes it makes this terrbile nosie like there is a bag stuck in the fan or something. When I turn it off and on about 3 times it goes away and works fine. If I leave the AC on when I turn the car off and then turn the car back on with the AC still on, it does not make this noise (only once or twice.)
Anyone have any suggestions?
Old Apr 4, 2007 | 11:50 PM
Speedway's Avatar
Speedway
Can you tell if the noise is on the passenger or driver side?
Old Apr 5, 2007 | 09:28 AM
c3andc5's Avatar
c3andc5
Do you have an HVAC codes when you run diagnostics? Check for Code B0361. I have similar symptoms and the code is pointing to an actuator problem on my left side.
Old Apr 5, 2007 | 09:51 AM
GUSTO14's Avatar
GUSTO14
Originally Posted by Bfail
When I turn my Air Conditioning sometimes it makes this terrible noise like there is a bag stuck in the fan or something. When I turn it off and on about 3 times it goes away and works fine. If I leave the AC on when I turn the car off and then turn the car back on with the AC still on, it does not make this noise (only once or twice.)
It sounds like you have some debris in the blower cage. I recommend you drop the blower motor and find out what it is. Dropping the blower motor is about a 30 minute job and doesn't require any special tools. The instructions are in the Helms service manual and are very thorough. Start by removing the panel under the dash on the passenger side and you will see what I'm talking about.
Clean the squirrel cage and the vibration will go away. If you don't get the debris out of there, the out of balance condition will ruin the bearings in the blower motor and shake the dash loose...
Good luck... GUSTO
Old Apr 5, 2007 | 10:36 AM
Bfail's Avatar
Bfail
Thanks, It does sound like it comeing from the passenger side.
To AC Problem
