What's Invloved with repalcing clutch MC?
Old Apr 4, 2007 | 06:33 PM
Chalky's Avatar
Chalky
St. Jude Donor '08-'09-'10
Default What's Involved with replacing clutch MC in C5?
Having clutch issues but have decided to try the simple solutions 1st. What is involved in doing an R&R on clutch master cylinder?
TIA!
Old Apr 4, 2007 | 07:25 PM
BaneZ06's Avatar
BaneZ06
Supremacy 1 car at a time
Disconnect the rod from the pedal, disconnect the hydraulic line from the slave cylinder, remove the fluid reservoir, twist the MC 45 degrees and pull it out
Old Apr 4, 2007 | 08:06 PM
Chalky's Avatar
Chalky
Is bleeding necessary? Seems like it would be!
Old Apr 4, 2007 | 08:19 PM
BaneZ06's Avatar
BaneZ06
Yes if you replace the MC youll need to bleed it. Replacing it shouldnt take your more than half an hour
Old Apr 4, 2007 | 09:23 PM
bb609's Avatar
bb609
Have you tried just changing the fluid in the reservoir several times first? It's a good thing to do on a regular basis anyway.
Old Apr 4, 2007 | 09:29 PM
davidfarmer's Avatar
davidfarmer
it has a dry-break, so changing it shouldn't necessarily require bleeding. Of course, you have to have a special tool to break the dry-break fitting!
To What's Invloved with repalcing clutch MC?
