Help, Help. Quick Question regarding a problem
Old Apr 4, 2007 | 08:46 PM
MTG MAN's Avatar
MTG MAN
Cruising
Default Help, Help. Quick Question regarding a problem
I posted this same problem a couple of weeks ago. Once again, when I turn over the ignition, I get nothing. Everything works, except the engine turning over. It even shows about 13 apms. This same thing happened before, but later in the day, it started. It's been several days and nothing. I tried to jump it just incase it needed a little more amps.
I have tried to unlock it from the door to reset the alarm/anti-theft mechanism, still nothing.
Please help with thoughts...
Old Apr 4, 2007 | 09:17 PM
bb609's Avatar
bb609
Bad ground starting with the battery.
Old Apr 4, 2007 | 11:28 PM
happa's Avatar
happa
Samething happen to me, look behind the ignition and there should be 2 white wires. One of them might be broke or barley hanging on. My was broke and wouldnt crank. If not Im sorry and hopefully someone can help. Good Luck
Old Apr 5, 2007 | 09:52 AM
dougbfresh's Avatar
dougbfresh
Neutral Safety Switch maybe?
Old Apr 5, 2007 | 10:24 AM
elgallo559's Avatar
elgallo559
does it make any sounds at all when you turn the key? My car would not start all I heard was the starter clicking when I turned the ignition. I took the starter off and took it to O'rielly's. They benched checked it and yup it was bad.
Old Apr 5, 2007 | 11:57 AM
Doug@MorosoPerformance's Avatar
0Doug@MorosoPerformance
Former Vendor
Or corrossion on the positive battery terminal
Old Apr 5, 2007 | 08:01 PM
65GGvert's Avatar
65GGvert
Two things, first it's volts, not amps you're reading, and 13 is more than enough to start your car.
Second, you said the engine was turning over. Was it turning at normal speeds like it does when it does start, or is it just barely turning? ]
Did you change the battery after the first time you posted? Did you check the grounds and the battery cables?
Old Apr 5, 2007 | 08:19 PM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Smells like a ground somewhere to me............
Old Apr 8, 2007 | 10:44 AM
MagRed04C5's Avatar
MagRed04C5
A4 or 6Speed?
If A4 try neutral instead of park.
With a 6Speed I think shifter has to be in reverse gear
and the clutch depressed.
To Help, Help. Quick Question regarding a problem
