Whow, My C5 Won't..
Old Apr 4, 2007 | 11:20 PM
C5VetteJoe's Avatar
C5VetteJoe
Default Whow, My C5 Won't..
Whow, Mt C5 Won't open it's hatch....!!! HELPS PLEASE!!
Hi All,
I've been a member since 2002, I read the forums alot, but almost never post...Here is my probem,
I have a C5 2002 A4 with only 2700 miles, I drove it today and I habe 2 problems...
1. The hatch will not open!! It won't open when I push the remote switch on my kay chain nor when I push the button on the consol. I know for a fact that there is nothing stuck in the grooves.
How exensvive is the fix? What is the fix? I have tried to push up on the hatch form the inside...
2. The da ..m glove box won't close....I have played with the switch but to no availl...
Please help!!
Also, whre should I take it ot get it fix...if need be .. in Houston, Tx
Thanks ALL!!!!!!
Joe
Old Apr 4, 2007 | 11:21 PM
C5VetteJoe's Avatar
C5VetteJoe
Sorry for the typo's but I am not a good typist...
Old Apr 5, 2007 | 12:21 AM
Bill Dearborn's Avatar
Bill Dearborn
Did you make sure your glove box latch didn't accidentally get pushed into the closed position? When that happens the glove box door just bounces off the striker plate until the latch is opened and can engage the striker properly.
As for the rear compartment lid check Fuse #26, Fuse #32 and Relay 39 in the Instrument Panel Fuse Block. On the right hand B pillar check Ground 302 and Splice Pack 302.
Bill
Old Apr 5, 2007 | 12:32 AM
C5VetteJoe's Avatar
C5VetteJoe
Bill,
Thanks for the input, I'll check the fuse box...but would I still hear a mechanism sound when Ipush the button to open hatch if the fuse was blowned??
Joe
Old Apr 5, 2007 | 07:26 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Originally Posted by C5VetteJoe
Bill,
Joe
no
Each latch has a small cable extending out of it, you should be able to pull the cables to manuall release the latches and and push the hatch open.
Old Apr 5, 2007 | 09:12 AM
myk7's Avatar
myk7
As a work-around, you can push the trunk button and then (with the windows up) close the door, it should pop the trunk up a bit, assuming the mechanism is trying to work.
Old Apr 5, 2007 | 09:37 AM
C5VetteJoe's Avatar
C5VetteJoe
Thanks, I'll try that as well!!
Old Apr 5, 2007 | 11:22 AM
FASST LN's Avatar
FASST LN
Also, try pushing down on your hatch (maybe 30 pounds of pressure) and then hit the hatch button.
Just to support what Bill mentioned about the glovebox, that happens to mine several times a year. I just have to grab the outside handle and pull on it (as if the glovebox was closed and I'm trying to open it). Sometimes, as Bill already stated, the little catch piece gets closed prematurely and won't latch on to the clasp. Very easy fix. Takes 5 seconds.
Old Apr 5, 2007 | 12:32 PM
randomus's Avatar
randomus
You should try opening the hatch with the cables in the back to see if maybe its just stuck. The cables are really thin wound steel with small metal ends. They are all the way in the back on each side. I think its easier to find them if you take off the storage compartment lids. Once you pull them you can manually push the hatch up.
Old Apr 6, 2007 | 02:09 PM
ersatz928's Avatar
ersatz928
If the fuses and hatch relay are OK, it could be the BCM. (it controls the relay) Check all the BCM power fuses (I think there are 3)
To Whow, My C5 Won't..
