I'm about to replace my brake fluid with Motul RBF 600 which was supplied with my stage 2 brake kit. Whats required to flush out the old brake fluid...just blow out the master cylinder with compressed air along with supply lines. I'm replacing the calipers and flex hoses also.
Do not blow your system out with air. If you do you will get air in the ABS module and that will cause you lots of problems. Just suck out the fluid in the master cylinder and fill it with Motul. Then bleed a full bottle of Motul through the system by bleeding at all four wheels. You will be good to go then. Good luck
Shirl Dickey
SD Racing Enterprises
No change in Sudbury since CVRD took over Inco or Xstrata taking over Falconbridge....with the price of nickel their making a ton of cash....if the smelter is down they lose 150,000/hr...something like that.
Originally Posted by rws.1
Most autoparts stores carry a brake suction kit ( Mightly mite) or you can install speedbleeders www.speedbleeders.com which makes it real easy.
