My starter is trapped in my headers!!! HELP!
Old Apr 5, 2007 | 07:59 PM
dougnstein's Avatar
dougnstein
Default My starter is trapped in my headers!!! HELP!
One of the terminals on my starter broke off today and since i let the man at the exhaust shop weld my downpipe together i have to remove both of the SLP headers to free up the starter...
My big question is If i can remove the solenoid from the starter motor and replace it with one from the new starter without physically removing the starter from behind the headers. I believe i can loosen it up enough to turn it upside down and get access to the solenoid assembly. After i can touch it, i believe there are 3 or so screws that attach it's casing to the cast assembly on the starter itself. Besides the lead that goes to the starter motor what else is connecting the solenoid to the starter motor? I feel like i will encounter a cluster or problems once i remove this...
Is this idea insane and doomed for failure?
Any advice would be greatly appreciated as i am rather not looking foward to doing the complete header install again b/c of a simple starter replacment...
Thanks everyone!
Doug
Old Apr 5, 2007 | 09:12 PM
corvettedoug's Avatar
corvettedoug
I just checked my old starter I had sitting around. It looks like there are those three speciality screws (look like torx but inside out) and the screw that connects the wire from the solenoind to the starter itself. Should be a fun puzzle to take it apart with out removing the exhaust.
Old Oct 28, 2011 | 02:30 PM
subnine79's Avatar
subnine79
i just did mine , have kooks headers on a 2000 convertible took 3 hrs . had to remove header and shift it around alot it will go in from the bottom went with a world power unit new 100 dollars dont want to do it again get a new starter and take your time
Old Oct 28, 2011 | 03:27 PM
95BlueBomber's Avatar
95BlueBomber
I saw the same bolt heads on a Jeep, reverse torx, the sizes start with an E. You can buy the sockets at autozone.
If it were me I would remove the mid pipe from the muffler flanges and header flanges and drop that passenger side header enough to remove the entire starter. If you are worried about grinding afterwards I wouldn't. I just removed mine to install my American Racing Headers and it goes back in there really tight. There is a certain spot the starter hits to line up and its a nice snug fit.
Good Luck!
Old Oct 29, 2011 | 10:31 AM
subnine79's Avatar
subnine79
its a 4 mm long socket to remove solenoid cant be done on the block check world power in Pennsyl chinajunk i dismantled mine and it has the same arm and fields as ac delco and a new timken berring whats with that i dont know its about time we are selling the imports parts for aftermarket ac delco is 400 new chineeeeees with american parts 100 go figure
Old Oct 29, 2011 | 12:55 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
that brand is a nightmare, the wires go through the tubes, it's insane
the socket needed is E5, Snap On has them also
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
Umm guys, this thread is from 2007
Old Oct 29, 2011 | 01:01 PM
mojo1's Avatar
mojo1
St. Jude Donor '06 thru '15, '19
hope it got the starter out of his headers....
To My starter is trapped in my headers!!! HELP!
