My 427 Project
Old Apr 5, 2007 | 09:50 PM
7LitreC5's Avatar
7LitreC5
Default My 427 Project
A while back I decided to forsake FI and do a big inch engine for my C5. I did a ton of research and decided to do a 427.
I bought all of the parts from Corvette Forum and LS1 Tech sponsoring vendors. A local shop, RMCR, is doing the assembly work for me. Today I stopped by and the long block was just about done (no valvetrain yet).
Tip of the day: I converted to a LS2 pan. The oil filter on the 07+ engines is different than previous years.
Old Apr 5, 2007 | 09:57 PM
LS7 C5's Avatar
LS7 C5
Started same project only with LS7 heads. Motor being built now.
Was stock LS1 with maggie and LT headers.
Old Apr 5, 2007 | 10:01 PM
TheCartel's Avatar
TheCartel
Looks great. Can't wait to see the numbers it puts down!
Old Apr 5, 2007 | 10:21 PM
berryj's Avatar
berryj
Looks great! Just for my own info what is the difference between a LS7 block vs another 427 engine?
Old Apr 5, 2007 | 10:30 PM
7LitreC5's Avatar
7LitreC5
The LS7 block (what I have) with a stock stroke yields 427 ci (427.7 ci actually). There are several other combinations of bore and stroke that will give you the same displacement on a LSx.
Old Apr 5, 2007 | 10:33 PM
7LitreC5's Avatar
7LitreC5
Me too. It should be installed in 2 or 3 weeks. The shop is real busy right now.
I am going to tune it myself using EFILive. I'll do drivability and idle first and then rent the dyno and finish the tuning.
Old Apr 6, 2007 | 08:04 AM
see5's Avatar
see5
I just did the same motor in a friend's C5. LS7 wet sump with c6 pan/ported l92/l76. Great combo!
Mine is 402 with same heads, intake.
The idle tuning will be a real challenge, let me know when you are ready-
Old Apr 6, 2007 | 08:09 AM
DRIVER456's Avatar
DRIVER456
From: NY- 2013 Corvette Challenge Champion-2013 Index Combo Champion 2015 CC/MM Champion
St. Jude Donor '07
Wow that looks nice.Do you have a part # for the oil pan? Did you have to get a new low oil sensor or does the LS1 fit?..........Paul
Old Apr 6, 2007 | 08:58 AM
see5's Avatar
see5
12581810-lS1/6 pickup,tray,and sensors fit
Old Apr 6, 2007 | 10:55 AM
Sully C5's Avatar
Sully C5
Cruise-In II Veteran
You will love the 427...this is the engine that should be in ALL Corvettes! We built ours off the C5R-427 block.
Old Apr 6, 2007 | 11:19 AM
gorillavet's Avatar
gorillavet
Having had one now for over a year I can tell you it is a joy to drive everyday. Mine is a daily driver and has been very docile on stop and go traffic in Atlanta. The torque is right there when you want it (400 rwftlbs at 2500rpm )so you always have the power quickly available. There is really no substitute for cubic inches.
Old Apr 6, 2007 | 07:33 PM
7LitreC5's Avatar
7LitreC5
Thanks for the offer of idle tuning help. I'll be in touch!
Old Apr 6, 2007 | 07:37 PM
7LitreC5's Avatar
7LitreC5
Today I decided to splurge. I had the shop order me a set of Katech valve covers and coil relocation brackets.
Old Apr 6, 2007 | 07:49 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Awesome! Cant wait to see the numbers!
Old Apr 6, 2007 | 08:18 PM
Just Enough's Avatar
Just Enough
You will love that motor, I built a Darton sleeved 440 for my Z with a very similar cam 232 240 117 and it is an electric motor freight train. low speed roll ons in fourth and fith from 30mph are unreal. With a mild cam like this, for having a lot of displacement, the power and torque are really controllable. Idle tuning is tough with the LS2 90mm. Have fun.
John
Old Apr 6, 2007 | 09:32 PM
LT1driver's Avatar
LT1driver
why does the 90mm TB make the tuning difficult???
Old Apr 6, 2007 | 10:14 PM
7LitreC5's Avatar
7LitreC5
I was going to ask the same question...
To My 427 Project
Old Apr 7, 2007 | 12:50 AM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
Very cool... Enjoy
Old Apr 7, 2007 | 07:51 AM
see5's Avatar
see5
In general the GM LS2/7 is a non issue. With large displacement or particularly with L92's high intake air volume plus cam, the idle throttle opening must be "induced".
Old Apr 7, 2007 | 08:03 AM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
I just wanted to thank you guys for installing the 427s and figuring it out. Im sure in a couple years Ill be do for a new motor and you guys will have it all figured out.
