New owner needs help with Tires
Old Apr 6, 2007 | 01:15 PM
Allen S's Avatar
Allen S
Cruising
Default New owner needs help with Tires
I am the proud new owner of 2000. It seems that the original owner changed the wheels and tires. The current tires are 265/40/17(F) and 295/35/19 (R) non run flat.
They only have about 21,00 miles on them. What should I expect for miles before I need to change them.
What would you recommend to replace them with. I will be driving the all the time. So yes for wet weather I will most likely park it when it snows.
Anyonea help would be appreciated.
Old Apr 6, 2007 | 02:12 PM
Sully C5's Avatar
Sully C5
Cruise-In II Veteran
Which brand of tire?
Also, if the front to rear diameter difference (should be ~0.5"-1.2" I believe) is outside the optimum range for Active Handling, it could have an impact.
Old Apr 6, 2007 | 04:25 PM
Allen S's Avatar
Allen S
Cruising
they are goodyear eagle f1 supercar
Old Apr 6, 2007 | 04:45 PM
Sully C5's Avatar
Sully C5
You are good for many more miles unless you like doing burnouts.
BTW I don't see 295/35 ZR19's listed???
http://www.tirerack.com/tires/Spec.j...irePageLocQty=
Old Apr 6, 2007 | 05:55 PM
Allen S's Avatar
Allen S
Cruising
They are 18's sorry
My main concern is the in inside has about 4/32 but the out a way below that
I am also wondering what I should replace them with when it time
Old Apr 7, 2007 | 10:44 AM
GUSTO14's Avatar
GUSTO14
Originally Posted by Allen S
They are 18's sorry
I have the Supercars on my 2000 Hardtop and absolutely love them. I also have the Goodyear GS-D3's on my 1985 and like them as well. I don't normally drive either in the rain if I can avoid it, but the GS-D3's are awesome in the wet. I think either is an excellent choice and while not inexpensive, great value for the money.
I happened to be following our club on a recent cruise and the car in front of me (a C4) had just switched to GS-D3's. We got caught in a shower and I was getting drenched by the C4 in front of me so I pulled out into the second lane. It was immediately obvious that of all of the Corvettes (C4's, C5's and C6's) he was throwing off much more water than anyone else... convinced me!
Good luck... GUSTO
To New owner needs help with Tires
