AC on and rough idle / stalling problem
Old Apr 6, 2007 | 11:30 PM
gchagrin's Avatar
gchagrin
8th Gear
Default AC on and rough idle / stalling problem
Hey folks...have a strange problem that started 2 months ago. Since it will get hot real fast here in AZ, I need to resolve.
When my car (C5 vert) is parked in the garage overnight and during the day at work, the car idles and doesn't stall when AC is on.
However...when the car is parked outside for period of time, or when I start it again shortly after stopping, the idle is rough and car stalls when AC is on. When I turn AC off, car is fine. If I drive car for 5 minutes or so and turn AC back on, idle will be fine again.
I know the AC is supposed to trigger a higher idle response and that seems to work in the garage situation....is there something to having the engine cool or outside temp reading cooler?
What electronics, etc. are associated with AC being on? Will Idle relearn procedure with AC on work?
The car is heavily modified with cam, heads, header, ECM software, etc...however all this was fine until now.
Thanks much
Old Jun 3, 2007 | 12:03 AM
ssteelma's Avatar
ssteelma
Default Me too...
Yeah - I have EXACTLY the same problem - mine's stock so mods are probably not the problem. Will keep looking.......
Old Jun 3, 2007 | 12:47 AM
marky_24's Avatar
marky_24
go to where ya had the car tuned and have them change your target idle speed vs coolant temp, that should fix it.
To AC on and rough idle / stalling problem
