Anyone Changed their own clutch?
Old Oct 15, 2001 | 04:26 PM
C5SilverBullet's Avatar
C5SilverBullet
CI 4, 5 & 9 Veteran
St. Jude Donor '08-'09-'10
Default Anyone Changed their own clutch?
I am thinking of doing it myself and wondered if it was possible. Sure looks tough!
Old Oct 15, 2001 | 06:46 PM
davidfarmer's Avatar
davidfarmer
Default Re: Anyone Changed their own clutch? (C5SilverBullet)
You really need a lift and a trans jack, as you have to drop the entire rear subframe and slide the transaxle and torque tube back several feet. Once that is done, the clutch is the same as any other car.
Old Oct 15, 2001 | 06:54 PM
Bluvette1's Avatar
Bluvette1
Its quite a bit of work to do it in your garage.
Old Oct 15, 2001 | 07:15 PM
C5SilverBullet
CI 4, 5 & 9 Veteran
Default Re: Anyone Changed their own clutch? (Bluvette1)
I have a lift and compressor and all those neat toys in the garage.
Old Oct 15, 2001 | 08:37 PM
DALE C's Avatar
DALE C
I HAVE DONE MINE TWICE WITH JUST A FLOOR JACK AND A 2 FOOT PIECE OF 2X12. I PUT THE BOARD UNDER THE LOW SPOT ON THE TRANS AND REAREND AND LET THEM DOWN TOGETHER WITH THE FLOOR JACK. ITS NOT VERY HARD JUST TIME CONSUMING, THE FIRST TIME TOOK ME ABOUT 12 HOURS THE SECOND TIME ONLY TOOK ABOUT 8. THERE IS AN ARTICLE WITH LOTS OF GOOD INFO IN THE MARCH 2001 CORVETTE FEVER.
GOOD LUCK
Old Oct 15, 2001 | 09:27 PM
MDT's Avatar
MDT
C5SilverBullet,
I'd be game. I think the least that you'll need will be a tranny cradle that attaches to your floor jack so that you can manipulate the tranny and differential assembly when you get it detached.
If you decide to give it a shot, keep us informed. It may turn out easier than you think.....or maybe it is something you'll only do once. :D
Didn't read your post indicating that you had a lift before posting. Sounds like all you need is something to support it when ready to pull it back. For God's sake be careful.....that's a lot of weight to wrestle with if you don't have proper support.
Good luck.
Mark
[Modified by MDT, 7:30 PM 10/15/2001]
Old Oct 16, 2001 | 12:47 AM
Shinobi'sZ's Avatar
Shinobi'sZ
Default Re: Anyone Changed their own clutch? (MDT)
Whoa........I was going to try this..but my installer told me he would do it for $300 bones. The last thing I did was my poly urethane bushing kit........that was also time consuming......but I was on vacation. Good Luck and may the clutch be with you! :cool:
Old Oct 16, 2001 | 01:18 PM
kewlbrz's Avatar
kewlbrz
Cruise-In II Veteran
Cruise-In III Veteran
Heres what your in for:
Old Oct 16, 2001 | 02:16 PM
Matt Gruber's Avatar
Matt Gruber
Default Re: Anyone Changed their own clutch? (kewlbrz)
On my 61 i did not want to crawl under the car,so i pulled the engine with clutch. no problem.
Has anyone pulled the engine from the top with a hoist? Seems the clutch would come out without messing with the trans or rear. I know the dealer uses a lift and drops the engine out the bottom when they do it, and, i believe it is faster for them.
i just want to do the job safely at home by myself without killing myself. (i plan to get aC5 soon and do lots of mods)
Old Oct 16, 2001 | 02:37 PM
Gary2KC5's Avatar
Gary2KC5
Default Re: Anyone Changed their own clutch? (drives61)
When the dealer pulled my engine it came out the bottom.
Old Oct 16, 2001 | 02:43 PM
Mag Red Monster's Avatar
Mag Red Monster
Elite Member
Cruise-In IV Veteran
Sounds like fun if you have the time and patience :yesnod:
To Anyone Changed their own clutch?
