What you buying is maybe $10-15 worth of bolts, washers and nuts...and hopefully grade 8 fasteners at that.
For no cost, you can lower your car with the oem bolts by maybe 1/2-5/8"...you can lower it a little more by cutting off the factory bushings. That may effect ride quality. Depending on your cars suspension, lowering it to much might bottom out your shocks. You will need to get the car aligned once the suspension settles after the lowering.
I knew about the alignment, not a problem, how would I lower the car using OEM bolts?
Above is one link with lowering instructions. There are several others out there if you look around. Mine is plenty low for me on the stock bolts. Give it a day or two to settle before you pass judgement on the height.
I'd start by lowering on the stock bolts and see if that works before spending money to get the "aftermarket" lowering kits. This is lowered all the way on the front bolts WITHOUT cutting the bushings, and with 2-3 threads left showing on the rear bolts. It's plenty low.
I figure it took it down close to an inch all the way around.
IMO reducing suspension travel without changing spring/shock rates will not be good for cornering.
Re: the OP, I had a bad experience because the prior owner cut the bushings on my car, i.e. three broken bolts due to fatigue failure and two ruined composite leaf springs... so I suggest working around cutting the bushings, i.e. high-quality longer rear bolts and something like the hardbar aftermarket front bolts/pads... tho lowering on stock front bolts+bushings should be able to get it pretty low.
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
I posted this last week, But will take the time here as well. After lowering with C6 adjusters in front and 1/2"x7" grade 8 bolts (the Forum standard) in the rear I became uneasy after reading of a member snapping one of these bolts off at the threads. Knowing the stock bolts are 14mm and that 14mm falls between 1/2" and 9/16" I installed grade8 9/16x7" bolts washers and nylocks. They fit fine are much stronger than 1/2" and believe that the traditional 1/2" mod be reworded to 9/16" grade 8. I ordered all hardware from www.boltdepot.com for the same money as the mail order houses are getting for "kits."
Bro, Unless you want it SLAMMED to the GROUND, just lower using stock bolts. I was also wanting it to look low, and was a bit skeptical about the "kits", so I just did it myself. It looks great IMO, and I will not be needing more lowering. The front can be a B**** though
Your car is exactly the look I am going for. I read on digitalcorvettes that you should cut the bushings, I DO NOT want to do that. Which how to thread did you use?
Originally Posted by knowledgefreak
If you have a show car id say go for it.. It looks good
But this is for sure not a performance mod at all.
Your ride quality will suffer for sure
Wouldn't say I'm willing to fork out the $$$$ to be a competitive show car, and until I go FI, not sure if I have a high performance car. I think I'm in the middle of the two.
agreed.
It isn't a performance mod since it is more of an anti performance mod. Performance is lot more than a big engine.
If you find the front scraping alot after lowering here are some really good products that will help. I have all 3 an like i said earlier my tires tops are even with my fenders and I still can go over speed bumps with no scraping
CCA skid plate protectors
CCA Fat Mamas (or fat daddys)
and pm Nasty98 for his rocker panel protectors
