P0128
Old Apr 8, 2007 | 06:35 PM
nitrouspaul's Avatar
nitrouspaul
Default P0128
Coolant thermostat(coolant thermostat below thermostat regulating temperature)
I am getting this code. I clear it then after a week or so it comes back.
Any ideas where to fix it?
Thanks all in advance
as for the temperature it all runs fine
Old Apr 9, 2007 | 02:38 AM
Bill Dearborn's Avatar
Bill Dearborn
DTC P0128 is designed to detect a faulty thermostat. Basically, if engine coolant temp doesn't reach 167 degrees after driving about 1.5 miles this code will set. There are a couple of conditions on start up temp and how hard the engine is working but it is basically saying it is taking too long to warm up the engine. Probable causes are faulty thermostat or a skewed engine coolant temperature sensor. Here is some of the diagnostic info:
DTC P0128
Circuit Description
An engine coolant temperature (ECT) sensor monitors the temperature of the coolant. This input is used by the powertrain control module (PCM) for engine control, and as an enabling criteria for some diagnostics.
The air flow coming into the engine is accumulated and used to determine if the engine has been driven within conditions that would allow the engine coolant to heat up normally to the thermostat regulating temperature. If the coolant temperature does not increase normally or does not reach regulating temperature of the thermostat, diagnostics that use ECT as enabling criteria, may not run when expected.
If engine coolant fails to reach a preset target temperature before a calculated air flow is accumulated DTC P0128 sets.
Conditions for Running the DTC
DTCs P0101, P0102, P0103, P0112, P0113, P0116, P0117, P0118, P0125, P0500, P0502, P0503, P1111, P1112, P1114, P1115 are not present.
The start up engine coolant temperature is less than 70°C (158°F).
The intake air temperature (IAT) sensor parameter is between -7 to +55°C (19-131°F).
The engine is running between 120-1,200 seconds.
The vehicle speed is more than 5 km/h (3 mph) for more than 2.5 kilometers (1.5 miles).
The mass air flow (MAF) is between 15-75 g/s with the average more than 14 g/s.
Conditions for Setting the DTC
The calibrated amount of the engine runtime has been met.
The calibrated amount of engine air flow has been met.
The calibrated minimum engine coolant temperature of 75°C (167°F) has not been met.
Action Taken When the DTC Sets
The control module illuminates the malfunction indicator lamp (MIL) on the second consecutive ignition cycle that the diagnostic runs and fails.
The control module records the operating conditions at the time the diagnostic fails. The first time the diagnostic fails, the control module stores this information in the Failure Records. If the diagnostic reports a failure on the second consecutive ignition cycle, the control module records the operating conditions at the time of the failure. The control module writes the operating conditions to the Freeze Frame and updates the Failure Records.
Conditions for Clearing the MIL/DTC
The control module turns OFF the malfunction indicator lamp (MIL) after 3 consecutive ignition cycles that the diagnostic runs and does not fail.
A current DTC, Last Test Failed, clears when the diagnostic runs and passes.
A history DTC clears after 40 consecutive warm-up cycles, if no failures are reported by this or any other emission related diagnostic.
Clear the MIL and the DTC with a scan tool.
Diagnostic Aids
Excessive coolant flow through the bypass hose to the throttle body may cause this DTC to set.
A skewed low ECT sensor can cause a P0128 to set.
Test Description
The numbers below refer to the step numbers on the diagnostic table.
This step tests for excessive resistance in the ECT circuit.
This step tests for a skewed sensor through the range of temperatures affecting this DTC.
Step
Action
Values
Yes
No
Schematic Reference: Engine Controls Schematics
Connector End View Reference: Powertrain Control Module (PCM) Connector End Views or Engine Controls Connector End Views
1
Did you perform the Diagnostic System Check-Engine Controls?
Go to Step 2
Go to Diagnostic System Check - Engine Controls
2
Important
The PCM will enable the engine cooling fans when certain ECT diagnostic trouble codes are set.
Is the cooling system coolant low?
Go to Loss of Coolant in Engine Cooling
Go to Step 3
3
Disconnect the ECT sensor.
Connect a 3-amp fused jumper wire between the signal circuit and the low reference circuit of the ECT sensor.
Observe the ECT sensor parameter with a scan tool.
Is the ECT sensor parameter more than the specified value?
138°C (280°F)
Go to Step 7
Go to Step 4
4
Connect a 3-amp fused jumper wire between the signal circuit of the ECT sensor and a known good ground.
138°C (280°F)
Go to Step 5
Go to Step 6
5
Test the ECT sensor low reference circuit for a high resistance or an open. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Did you find and correct the condition?
Go to Step 10
Go to Diagnostic Aids
6
Test the ECT sensor signal circuit for a high resistance or an open. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 10
7
Remove the ECT sensor. Refer to Engine Coolant Temperature (ECT) Sensor Replacement .
Suspend the ECT sensor and a thermometer in a pan of water.
Place the pan on a burner or hot plate.
Test the resistance of the ECT sensor through the specified range of temperatures. Refer to Temperature vs Resistance .
Does the resistance and temperature closely match the Temperature vs Resistance Table?
10- 90°C (50-194°F)
Go to Step 8
Go to Step 9
8
Install the ECT sensor. Refer to Engine Coolant Temperature (ECT) Sensor Replacement .
Is the action complete?
Go to Thermostat Diagnosis in Engine Cooling
9
Replace the ECT sensor. Refer to Engine Coolant Temperature (ECT) Sensor Replacement .
Did you complete the replacement?
Go to Step 10
10
Clear the DTCs with a scan tool.
Turn OFF the ignition for 30 seconds.
Start the engine.
Operate the vehicle within the Conditions for Running the DTC. You may also operate the vehicle within the conditions that you observed from the Freeze Frame/Failure Records.
Did the DTC fail this ignition?
Go to Step 2
Go to Step 11
11
Observe the Capture Info with a scan tool.
Are there any DTCs that have not been diagnosed?
Go to Diagnostic Trouble Code (DTC) List
System OK
Bill
