cruise control problems
Old Apr 9, 2007 | 08:01 AM
Mark F's Avatar
Mark F
Cruising
Default cruise control problems
I just bought a 1999 this weekend. Everything on the car is in excelent shape and the previous owner spent tons of money fixing the car up. The only thing I can find wrong is the cruise control does not work.
I checked the fuse and it is good.
The previous owner said his mechanic had just put a new 80mm throtle body on 2 weeks earlier so I wonder if something could be wrong with this installation.
Where should I look next?
Thanks in advance for any feed back received.
Mark
Old Apr 9, 2007 | 01:14 PM
blevett's Avatar
blevett
sorry... wrong car.
Old Apr 9, 2007 | 03:17 PM
Bill Dearborn's Avatar
Bill Dearborn
First make the following checks in order:
1.Inspect for proper operation of the brake lamps. Refer to Exterior Lighting Systems Description and Operation in Lighting Systems.
2.Inspect for proper operation of the clutch, if equipped with a manual transmission. Refer to Clutch System Description and Operation in Clutch.
3.Electro magnetic interference (EMI) on the vehicle speed sensor signal circuit may cause erratic cruise control operation.
Let us know what you find. If you don't find the problem then run the On Board Diagnostics to see what codes show up and post them here.
By the way the cruise control function is electronic not vacuum. Here is a description of how it operates:
Cruise Control Description and Operation
Cruise control is a speed control system that maintains a desired vehicle speed under normal driving conditions at vehicle speeds above 40 km/h (25 mph). Steep grades may cause variations in the selected vehicle speeds.
The following are the main components of the cruise control system:
The powertrain control module (PCM)
The On/Off switch
The Resume/Accel switch
The Set/Coast switch
The TCC/brake switch
The stop lamp switch
The throttle actuator control (TAC) module
The Clutch Pedal Position (CPP) switch, if equipped with a manual transmission
Cruise Control Engaged
The TAC module monitors the signal circuits of the following cruise control switches:
On/Off
Resume/Accel
Set/Coast
The PCM will engage and adjust vehicle speed based on the information received from the TAC module via the UART serial data link. For further information on the TAC system, refer to Throttle Actuator Control (TAC) System Description in Engine Controls--5.7 L.
The cruise control switches are located on the multifunction/turn signal lever.
Ignition positive voltage is supplied from the 10 ampere CR CONT fuse to the cruise control switch via the ignition 1 voltage circuit. When the normally open cruise control On/Off switch is turned On, the switch closes and the TAC module detects a high signal voltage on the cruise control on switch signal circuit. When the normally open Set/Coast switch is pressed, the switch closes and the TAC module detects a high signal voltage on the cruise control set/coast switch signal circuit. To engage the cruise control system, turn the On/Off switch On and momentarily press the Set/Coast switch. The TAC sends a UART message to the PCM, in order to confirm that the cruise control enable criteria has been met. The PCM will engage the cruise control system and record the selected vehicle speed. The PCM sends a class 2 message to the instrument panel cluster in order to illuminate the cruise control indicator. Pressing the accelerator pedal, while the cruise control system is engaged, will allow the driver to override the cruise control system in order to accelerate the vehicle beyond the current set vehicle speed. When the accelerator pedal is released, the vehicle will decelerate and resume the current set vehicle speed. The driver can also override the current set vehicle speed via the Set/Coast switch and the Resume/Accel switch. When the cruise control system is engaged, pressing and holding the Set/Coast switch will allow the vehicle to decelerate from the current set vehicle speed without deactivating the cruise control system. When the Set/Coast switch is released, the PCM will record the vehicle speed and maintain the vehicle speed as the new set vehicle speed. When the cruise control system is engaged, momentarily pressing the Set/Coast switch will allow the vehicle to decelerate at 1 MPH increments for each time that the Set/Coast is momentarily pressed, with a minimum vehicle speed of 23 MPH. When the normally open Resume/Accel. switch is activated, the switch closes and the TAC module detects a high signal voltage on the cruise control resume/accel switch signal circuit. Activating and holding the Resume/Accel switch, when the cruise control system is engaged, will allow the vehicle to accelerate to a greater vehicle speed than the current set vehicle speed. When the Resume/Accel switch is released, the PCM will record the vehicle speed and maintain the vehicle speed as the new set vehicle speed. When the cruise control system is engaged, momentarily activating the Resume/Accel switch will allow the vehicle to accelerate at 1 MPH increments for each time that the Resume/Accel switch is momentarily activated, with the maximum acceleration total of 10 MPH over the current set vehicle speed . Momentarily activating the Resume/Accel switch, after the cruise control system has been disengaged by pressing the brake pedal, will recall the previous set vehicle speed that is recorded in the PCM.
Cruise Control Disengaged
The PCM disengages the cruise control operation based on the information received from the TAC module. The TAC module monitors the signal circuits of the following switches:
The On/Off switch
The CPP switch
The TCC brake switch and the stop lamp switch are incorporated into an assembly and are mounted to the brake pedal bracket. Pressing the brake pedal while the cruise control is engaged will disengaged the cruise control system. The TAC module monitors the stop lamp switch signal circuit and the PCM monitors the TCC brake switch/cruise control release signal circuit. When the brake pedal is pressed, the normally closed TCC brake switch opens and the normally open stoplamp switch closes. The TAC module detects a high signal voltage on the stop lamp switch signal circuit and the PCM detects a low signal voltage on the TCC brake switch/cruise control release signal circuit. The TAC module sends a UART message to the PCM indicating the status of the stop lamp switch. The cruise control system will disengage when the cruise control On/Off switch is turned Off. The vehicle speed stored in the memory of the PCM will be erased when the Off button is activated, or the ignition switch is turned off.
The clutch switch is mounted to the clutch pedal bracket. Depressing the clutch pedal while the cruise control is engaged will disengaged the cruise control system. When the clutch pedal is depressed, the normally closed clutch switch closes and the PCM detects a low signal voltage on the clutch switch signal circuit.
The cruise control system will disengage when the PCM detects that the driver has the accelerator pedal override active for approximately 60 seconds.
When the cruise control system is disengaged, the PCM sends a class 2 message to the IPC in order to deactivate the cruise control indicator.
Cruise Control Inhibited
The PCM inhibits the cruise control operation when any of the following conditions exist:
A cruise control system related DTC has been set.
The vehicle speed is less than 40 km/h (25 mph).
The vehicle is in PARK, REVERSE, NEUTRAL, or 1st gear.
The engine RPM low.
The engine RPM is high.
The vehicle speed is to high.
The system voltage is not between 6 volts and 16 volts.
The antilock brake system/traction control system is active for more than 2 seconds.
Bill
Old Apr 9, 2007 | 03:30 PM
zeusoftexas's Avatar
zeusoftexas
Check the switchs that make contact with the back of the brake pedal.
I had to adjust mine to get my CC to work in my 97.
Old Apr 9, 2007 | 04:18 PM
blevett's Avatar
blevett
Sorry about the wrong advice on vacuum.... I had the wrong car on my mind.... and obviously wasn't thinking straight.
Thanks for correcting me Bill.
Old May 7, 2007 | 08:43 AM
Mark F's Avatar
Mark F
Cruising
Thanks for the replys.
I took the car to a dealer and he said the brake light switch was the problem. I purchased the replacement switch from them and installed it, bench testing the old one after removal I found the switch was opperating properly so obviously the switch did not need to be replaced.
The car is back at the dealer this morning and he wants to keep tacking on hourly charges after a two hour charge for the wrong diagnosis previously. Anyone got a schematic they can e-mail me?
Old May 7, 2007 | 10:49 AM
Bill Dearborn
Your profile doesn't allow anybody to send e-mails to you. PM me with your e-mail address and I will send you a word document with the diagnostic info and all of the schematics.
Bill
Old Aug 12, 2008 | 01:47 PM
xmattut's Avatar
xmattut
I have this same problem except my Cruise Control works sometimes and not other times. I already replaced the stalk and the problem still exists. I also get the usual U1096, U1064, and U1016 codes on the last code display catagory (i think it is B0 RFA Remote Function Actuation, but I can go look tonight).
Any solutions/suggestions?
Old Aug 13, 2008 | 01:20 AM
white90conv's Avatar
white90conv
Here is a schematic of the multifunction switch connection to the TAC. You can check the switch by disconnecting the connector at the TAC module and using a test light. Don't use a DMM as its high input impedance may cause faulty readings. The TAC is attached to the pcm and is accessed thru the rear of the passenger wheel well.
To cruise control problems
