Need power source added a heated seat
Old Apr 9, 2007 | 08:20 AM
zolman's Avatar
zolman
Default Need power source added a heated seat
Any suggestions where I should get my power source for a heated seat on a 99 convertible. The seat is reupholstered with heating elements. I just need power.
I know the easiest way is to tap into my cigarette lighter but my XM is already powered by that and I don't want to mess that up.
There are two empty fuse slots but how do you tape into those without creating other problems? I'm assuming I would have to remove the fuse box and get access from the backside?
Old Apr 9, 2007 | 09:54 AM
B-rent's Avatar
B-rent
Which cig lighter is you xm running off of? You could always run the wires under the carpet to behind the one in the center console or behind the ashtry one
Old Apr 9, 2007 | 02:33 PM
JEEP/C5's Avatar
JEEP/C5
You could use the factory accessory wires in the fuse box under the passengers’ feet. The 3 wires the factory left loose in the box (ground, power and turn on lead).
To Need power source added a heated seat
