raptor shift light tach output wire
Old Apr 9, 2007 | 04:58 PM
duvall408w's Avatar
duvall408w
Default raptor shift light tach output wire
Hooking up raptor shift light. Just wondering if i can just hook up the wires to the same wires i hooked my boost gauge up to and which wire is the tach wire of the coil and where did you tap into it at thanks robert
Old Apr 9, 2007 | 06:22 PM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
TTT
Need to hook mine up too. At one point I had directions on finding a tach wire inside the dash trim in a fairly accessible place, but I lost them
Old Apr 9, 2007 | 06:39 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
If you have the skills to locate it....this is the most accessible location to tap into it. Problem is there are several white wires in that bundle.
Tony, this is probably the thread you're thinking of:
http://forums.corvetteforum.com/showthread.php?t=619162
Old Apr 9, 2007 | 06:43 PM
Vettedreamer2's Avatar
Vettedreamer2
Remove bottom dash panel. By hood release there is a pack of about 15wires. In there u can use the pink wire for hot the black for ground (couple of them to choose from).
Then the fun part there are 4 white wires. Use a pin to attach to raptor light and set light at 2k then push pin into each white wire and rev engine when you see light working you have right one.
Took me about 45-60 min from start to finish
Old Apr 9, 2007 | 06:48 PM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
Good advice on finding the correct wire.
Old Apr 9, 2007 | 10:53 PM
duvall408w's Avatar
duvall408w
i hook mine up just like that went quick and painless I love this forum
To raptor shift light tach output wire
