airbag light question
Old Apr 9, 2007 | 07:51 PM
luckyone928's Avatar
luckyone928
Default airbag light question
i finished my project and now i have an airbag question. i replaced the bags and module and now when i turn on the key the light flashes 7 times and then stays on. one person i talked with says i need to replace the seatbelts, is that true? thans in advanced
Old Apr 9, 2007 | 08:21 PM
T VETTE's Avatar
T VETTE
I don't know your project but if a C5, my Mitchell crash book said to replace: Deployed air bag modules, sensors in area of impact, sensing & diagnostic module, seat belts in use at time of air bag deployment.
Now I suspect the seat belt listing is just to satisfy the lawyers, but if it has the lock up or charge type belt it does need to be changed out. If it functions normal than it probably is fine. You may just need a light reset from the dealer. If a side impact then side sensors need to be changed.
Old Apr 9, 2007 | 08:39 PM
luckyone928
i dont know if the belts were in use as it was wrecked when i bought it- i wasnt aware of any sensors, it was hit in the left front and yes its an 02'
Old Apr 9, 2007 | 08:48 PM
T VETTE's Avatar
T VETTE
Book said sensors in area of impact. You did not change any? We may have found the problem, or one of them.
Old Apr 9, 2007 | 09:04 PM
luckyone928
ill take a look at the service manual tomorrow, thanks for your help--mike
Old Apr 10, 2007 | 07:49 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
There are no sensors on a C5
I came across something in the service manual the other day when I was looking up an SDM code for someone else and I saw that the SDM communicates with the BCM every time the car is started (this makes sense) what I didn't realize is the process also involves the PCM, on startup the SDM and BCM communicate a code which is the last 4 digits of the SDM part number and then the BCM and PCM communicate to each other the VIN stored in each computer if these don't match up the air bag light will illuminate and throw the code that I looked up (I'll have to go back and look to see which code it was???)
I don't know what project you had but I think it's safe to assume since you said body damage that the airbags deployed, correct?
Did you also replace the SDM with the airbags?
I have a project of my own that I'm getting ready to flatbed up to GM for programming and I'll have to get more info on SDM programming.
As far as the seat belts go there is nothing electronic on the passenger side belt and the drivers side receiver is only wired to a switch which turns the "fasten seat belt" light off when the car is started.
Old Apr 15, 2007 | 05:04 AM
luckyone928
yes i replaced he bags and the controller- your saying tht i somehow need to have it reprogrammed with the existing vin?
Old Apr 18, 2007 | 06:00 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
I believe so, I'm getting ready to put power on my project car soon which not only has new bags and an SDM but also a new BCM as well as all other modules.
Old Oct 23, 2007 | 10:44 AM
stepuptata's Avatar
stepuptata
what is the SDM and BCM? My airbag light stays on as well. Like to get it to go off
Old Oct 23, 2007 | 11:21 AM
BlackZ06's Avatar
BlackZ06
Default Display codes
Display the codes .... go heere if you don't know how to do it ...
https://www.corvetteforum.com/techti...D=26&TopicID=1
I'll bet $20.00 you have a B1001 DTC set in the SDM ... along with possibly some others.
Post the codes ....
Old Oct 23, 2007 | 11:26 AM
BlackZ06's Avatar
BlackZ06
I'll save you the time ..... B1001
You need to perform two steps with a Tech2 to clear this code ...
1) Program VIN into the SDM
2) Program PROM ID into the BCM
The PROM ID is a 4 digit number that is supposed to be on a label on the SDM, but you can read it from the SDM with the Tech2 if you've already installed the SDM in the dash and don't want to take it back out.
Old Oct 23, 2007 | 11:34 AM
BlackZ06's Avatar
BlackZ06
SDM - Sensing and Diagnostic Module
BCM - Body Control Module
These are two of several computers in the car that communicate with each other on a serial data link.
The SDM controls the SIR (airbag) system, and in a deployment the SDM has to be replaced as it is permamnently "locked" with the last 5 seconds of certain vehicle data before the deployment.
The BCM controls certain functions such as the cars Security and Lighting systems. It contains certain vehicle data (such as the VIN) that at vehicle start is compared with other computers in the car to be certain that the "correct" computers are in the car. If, for example, the BCM and PCM VIN don't agree, the BCM will, through the PCM, prevent the car from being driven. The PCM is the Powertrain Control Module, the computer that controls the engine and transmission (if it is an automatic).
Old Oct 23, 2007 | 05:54 PM
stepuptata's Avatar
stepuptata
Default body modules
Were are these "body sensors located"? Thanks. Man, this stuff is over whelming
Old Oct 23, 2007 | 09:29 PM
BlackZ06's Avatar
BlackZ06
There are no "body sensors" other than the following
SDM - The SDM contains a decelerometer that calculates if vehicle is decelerating faster than certain pre-programmed parameters. If the vehicle is slowing faster than the parameters, the SDM fires the airbags. The SDM has its own short term power storage capability so that if the vehicles electrical system is damaged during a wreck, the SDM still has the power to deploy the bags.
On cars equipped with ACTIVE HANDLING (RPO JL4) there are two sensors - a yaw sensor and a lateral accelerometer. These have nothing to do with the airbag system, and only need be replaced if they have ceased to function. These two sensors are located in the cabin of the vehicle. DTCs will be set if either/both of these are inoperative. If they fail, ACTIVE HANDLING is turned off, but the vehicle is driveable.
Old Oct 23, 2007 | 10:11 PM
stepuptata's Avatar
stepuptata
Default air bags
my active handling idiot light always stays on as well as the airbag light. The DIC doesn't show a malfunction. If I press the active handling button on the console, the DIC will display that it has been disabled or active if turned on, but the idiot light is always on? Thanks for all the help!
Old Oct 23, 2007 | 10:13 PM
stepuptata's Avatar
stepuptata
Also, what is a Tech2 ???, too clear these lights once they have been corrected? Thanks.
Old Oct 23, 2007 | 10:27 PM
BlackZ06's Avatar
BlackZ06
You need to display the codes in the EBCM ... follow these instructions ... then post the DTC codes displayed. Be sure to post the entire code ... C1234H, for example.
The Tech2 is the GM handheld computer used to diagnose faults in the car. It is also used to re-program certain functions in the car's computers. The Tech2 can be used on almost any GM vehicle built after about 1990.
The Tech2 is VERY expensive (about $5,000 new), so only a handful of non-GM shops/people have one.
However, on a C5 we have the unique ability to learn a lot about what is wrong with the car by following the procedure above. A "poor man's" Tech2, if you will. A lot can be learned/fixed by displaying DTC info from the car. But, some functions such as programming the VIN in the SDM can only be done with a Tech2
Old Oct 24, 2007 | 06:08 AM
stepuptata's Avatar
stepuptata
thanks, I'll post the codes when I get the dash back in! thanks again
Old Dec 5, 2007 | 09:43 PM
jophis37's Avatar
jophis37
sorry for the hijack, I don't have a lot of faith in my local dealer. With me having an aftermarket tune, would I have to worry about the dealer messing w/ the tune, when they attemt to reset the sdm,and bcm?
To airbag light question
