I was able to buy a 33mm hub nut socket last night(thanks to AN G UELand Tex Vette). Got the nut off, but the hub doesn't seem to just pull off from the front? do I need a wheel puller, or does the axle shaft/a-arm stuff have to come off from the backside of the assembly first? Also if the latter, do I need a ball joint fork/tool? Sorry for all the Qs, but I've never done this before. i'm just trying to replace some broken wheel studs. Thanks
Check out the instructions (with pics) that Jake Latham has available. I've saved a copy of these at home for when I tackle the hub/bearing replacement. I think this will get you going.
