Bumper skid plate - replace or weld?
Old Apr 10, 2007 | 08:18 PM
Z06 KOS's Avatar
Z06 KOS
Default Bumper skid plate - replace or weld?
The part where the bolt goes through has broken off on the under-bumper skid plate... Should I replace or just weld it back?
Old Apr 10, 2007 | 08:58 PM
TTK98's Avatar
TTK98
A weld would probably crack again.I would try to braze it.
Old Apr 10, 2007 | 09:03 PM
dwestsr's Avatar
dwestsr
If you weld it , you need to use some sort of heat sink to prevent the rubber parts from melting. I would use a wet rag wrapped around the metal where it contacts the rubber. Secondly, I suggest that you weld it with a tig welder and add a backing plate to reinforce the repair. Whoever welds it must have the skill to weld thin material.
One other suggestion is to rivet a new bracket along side the original. That may be the easiest repair to do.
Good luck!
Old Apr 11, 2007 | 01:00 AM
Z06 KOS's Avatar
Z06 KOS
I was informed that this piece deflects air into the radiator, will driving without this piece make the car run hotter?
Should I be concerned with "spirited" driving?
Old Apr 11, 2007 | 01:13 AM
stngh8r's Avatar
stngh8r
I have went with out one before and you will definitely notice a increase in temps during the hot weather. I noticed it most while driving in "in town" conditions, while out on the open highway there seems to be enough air flow getting pushed to the radiator and it cools fine. But around town with the AC on, you will need that piece for proper cooling.
Hope that was helpful. I am about to replace mine for the 2nd time
Eric
Old Apr 11, 2007 | 02:15 AM
Z06 KOS's Avatar
Z06 KOS
Eric
how much is a new piece, do you have the GM part number by chance?
Old Apr 11, 2007 | 10:11 AM
stngh8r's Avatar
stngh8r
sorry, I dont remember the price or PN, I bought mine from Vette2Vette corvette salvage several years ago and havent inquired for a new one to replace the now broken one.
Old Apr 12, 2007 | 01:07 PM
Z06 KOS's Avatar
Z06 KOS
Just bought the entire front spoiler kit for $83 shipped from a reputable GM ebay vendor.
Not going to risk welding it and having it break and possibly going underneath my tires and causing accident during spirited driving.
To Bumper skid plate - replace or weld?
