Headlights
Passengers side headlight doesn’t come up 90% of the time. So I crank it up manually. I figure I need a headlight module. I haven’t gotten around to buying one cause I haven’t found a decent source yet. It is the same module as used on the firebird, sun bird and a few old Buicks. But popping the hood and hand cranking is cheesy. Last week I hit (I mean hit) the flasher button at the same time as I turned on the lights, and they both came up? I’ve been doing this every time I put the lights on and it has been working 99% of the time. Could this really be a ground problem with the ground running through the emergency flashers? Thanks in advance
