Climate control problem
Old Apr 12, 2007 | 10:22 PM
billdance's Avatar
billdance
Default Climate control problem
I read the many previous posts....but am still confused if I have the same problem..
Today....while the drivers side control was on 60....and the Passenger side was all the way to the left.....also coldest.... the passenger side was still putting out smoking HOT air!! No matter where I had the passenger control...east...north...west...still screaming hot...
I called corvettes of Houston and they said it may be the individual motor that controls the ???? must have gone bad... estimated $500!!
Anyone else have any Ideas... I just freaking dropped $2k.... 50K service...new brakes....battery..flush...allignment... .etc... and also FR RH headlight wouldn't raise anymore...new motor...actuator...etc.... DAMN....this is all I need.... more $$
1998 Conv... 46K miles....
I just installed a new K&M filter....so I DID disconnect the batt....so as per previous threads...I hope unhooking it and reconnecting may help...
any thoughts....
Old Apr 13, 2007 | 07:02 AM
beav626's Avatar
beav626
If you have the automatic A/C controls... With the car running and the A/C on, pull fuses 18 & 27 in the passenger floorboard box. Wait a minute, then put the fuses back in. This should 'recalibrate' the damper motors for you if that's the problem. If you have the manual/single zone A/C system this won't do any good, sorry.
Good Luck! Let us know how it turns out
Old Apr 13, 2007 | 10:41 AM
billdance's Avatar
billdance
Sorry.... Ummm..... how do I tell the diff.... I took a pic....but realized that I'm unable to attach it....
I've got two climate control temp adj...one for Driver...one for Pass.... On the left side of display is the fan adj...on the right is "AUTO" and "Mode"....
Old Apr 13, 2007 | 04:07 PM
billdance's Avatar
billdance
Well Beav...I hoped that would have worked....but no go.... still smokin heat coming out... Its either the HVAC circuit board or the individual motor that controls the door....
To Climate control problem
