C5 Diff Assembly Torque Specs
Paul
Fastener Tightening Specifications
Application
Specification
Metric
English
Differential Case Bolts
55 N·m
41 lb ft
Differential-to-Transmission Bolts and Nuts
50 N·m
37 lb ft
Drain Plug
35 N·m
26 lb ft
Driveline Support Assembly-to-Engine Flywheel Housing Bolts
50 N·m
37 lb ft
Electronic Brake and Traction Control Module (EBTCM) LH Mounting Bracket Bolts
50 N·m
37 lb ft
Fill Plug
35 N·m
26 lb ft
Left Side Cover Bolts
25 N·m
18 lb ft
Negative Battery Cable Bolt
15 N·m
11 lb ft
Pinion Housing/Cage Bolts
25 N·m
18 lb ft
Pinion Nut
500 N·m
370 lb ft
Propeller Input Shaft Bearing Positioning Bolts
35 N·m
26 lb ft
Propeller Shaft Hub Clamp Bolt
130 N·m
96 lb ft
Rear Cover Bolts and Stud
10 N·m
89 lb in
Rear Shock Absorber Lower Mounting Bolt
220 N·m
162 lb ft
Rear Suspension Crossmember Mounting Nuts
110 N·m
81 lb ft
Right Side Cover Bolts
25 N·m
18 lb ft
Ring Gear Bolts
195 N·m
144 lb ft
Shift Control Closeout Boot Retaining Nuts
12 N·m
106 lb in
Shift Control Mounting Bolts
30 N·m
22 lb ft
Transaxle Mount Bracket-to-Differential Bolts
50 N·m
37 lb ft
Transaxle Mount-to-Bracket Nuts
59 N·m
43 lb ft
Transaxle Mount-to-Rear Suspension Crossmember Nuts
50 N·m
37 lb ft
Transmission Oil Cooler Rear Pipe Fitting-to-Junction Fittings at Engine Flywheel Housing
27 N·m
20 lb ft
Transmission Shift Rod Clamp Bolt
30 N·m
22 lb ft
Transmission Stud Mount Bolts
10 N·m
89 lb in
Transmission Stud-to-Mount
42 N·m
31 lb ft
Transmission Wiring Harness-to-LH Transmission Case Retaining Bolt
2.5 N·m
22 lb in
Vehicle Speed Sensor Bolt
10 N·m
89 lb in
By the way I thought there was a special tool package that had to be used to repair the Getrag diff.
Bill
I found the Diff quite simple to work on and it all came apart very easily. Inside the differential, Getrag uses bellville springs to provide preload to the posi clutch packs. When the diff bolts are removed, it unloads one side of the clutch pack while the other side (inside the diff housing w/ring gear) is still under load. Until the spider gear shaft is removed, the other clutch pack cannot be serviced. It appears to remove the shaft, the assembly must be placed into a press and pressure placed on the side gear to remove the load from the spider gear shaft. Then the shaft can be removed and whole assembly can be serviced. Luckily, I have a press and machine shop in my Garage, so working on the diff is not a problem. I would need to make several special tools however, if the ring and pinion were to be switched out.
Do you know if these C5 ring and pinions can be set up using the pinion depth measuring method?
Paul
