IRS/Gear/Drivetrain/traction question
Right now i'm working on figuring out what i want to upgrade before adding drag radials...
I've concluded a brace and 300m long output shaft are a must. I'm going to take my chances on the short shaft/gear but now i'm thinking about while in there replacing the gears out to 4:10's... From my readings it's almost seems like they will be safer on the drivetrain than my stock gears as they wont' hit the tires as hard... am i wrong in this thinking????
( i based this off my reading in searches on both CF and LS1tech)
someone guide me here....
Also i've never done gears but there are alot of never dones before that i do that come out 100% ok... I've hear of chatter or whinning form diffs after an install like this.. Usually an clue something isn't right.
From the pictures/write ups.. it seems pretty straight forward. honestly i'd rather do it myself than trust a local mechanic on my car...
Thanks in advance... You guys are the best
With street tires it's over kill. With DR, im sure it helps
and about you installing your own gears, theres specials tools you need to do these rears.. i would get it done by a pro b/c theres special things we dont knwo that they do hah, and the slightest adjustment could cost you your gears whenmetal shavings are comming out of your drain hole....
I keep seeing everyone talk about upgrading their shafts are these a DIY job or does everyone send theirs off????
I'm confused a lil help here
what can i do my self back there and what should i run away from???
