Torque wrench ?
Old Apr 15, 2007 | 07:23 AM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
what size ratchet and how many FT LBS are you guys getting
Old Apr 15, 2007 | 09:56 AM
rws.1's Avatar
rws.1
Harbor Freight..... www.harborfreight.com
I have tested both against both Craftsman and Snap-on for accuracy... maybe I got lucky, but there is no discernable diference in accuracy.
Unless you are a professional and want it to last forever, spending any more is a waste of your money.
1/4" SQUARE DRIVE TORQUE WRENCH
Click-stop type accurate within /- 4%. Heavy duty cam and pawl mechanism. Reversible. Includes carrying case.
Drive: 1/4"; Torque range: 20 to 200 in. lbs; Length: 10"; Weight: 1 lb.
ITEM 94735-2VGA
$19.99
1/2" CLICKER TORQUE WRENCH
Click-stop type accurate within +/- 4%. Heavy duty cam & pawl mechanism.Reversible.
Carrying case. Lifetime Warranty.
Drive: 1/2''
Torque range: 10 to 150 ft. lbs
Length: 18"
Shipping weight: 4 lbs.
ITEM 239-5VGA
$11.99
Old Apr 15, 2007 | 10:41 AM
ErnieN85's Avatar
ErnieN85
Originally Posted by SleeperC5
Don't you just return Craftman tools for a replacement when they break?
Nope sears says there not hand tools!
I'v broken two of the 150 lb 1/2 sears Corp. in Chicago made the locals give me new ones after i complained enough now I have a 250 lb sears (hasn't broken yet) aa 150 1/2 from Griots (they will stand by it and calibrate for free) and a 1/4 inch lb from Harbour freight (cheap)
I'll use the Griots for critical stuff and the sears for the heavy duty stuff like the brake brackets and suspension parts which need higher torque.
Old Apr 16, 2007 | 01:46 PM
Brad@RevXtremeAutoSports's Avatar
When i did my heads and cam i used the manual type from sears. 29 dollars and is always accuarate. It can be a pain in that it does not operate like a regular ratchet however it is accurate and does not break.
Here is a link ---------> http://www.sears.com/sr/javasr/produ...TOOL&ihtoken=1
