*Help Needed* Speedometer & Skipshift not working.
Old Apr 14, 2007 | 01:27 PM
Yungn's Avatar
Yungn
Default *Help Needed* Speedometer & Skipshift not working.
Did some tranny work night before last. Got everything put back up (or so we thought) Everything seems to be in place but the speedo and skipshift is currently not working? Can someone point me in the right direction. Im gonna need a speedo, LOL. TIA
Old Apr 14, 2007 | 01:41 PM
myk7's Avatar
myk7
Well, the skipshift connector is on the drivers side of the tranny. Mine had a tag on it that said "shift" or something like that. I believe it's the only one on the drivers side. I believe there are 3 other connections on the right side and top, sounds like you have left one off.. just grab the harness and follow all pig tails and make sure they connect somewhere. I'm not sure if it's possible to have the wrong connectors in the wrong sensors.
Old Apr 14, 2007 | 01:52 PM
Just Enough's Avatar
Just Enough
I did the same thing and it was the rear axel speed sensor I forgot to re-connect on top of the differential toward the back on the passenger side. Plugged it back in and everything was fine.
Old Apr 14, 2007 | 01:57 PM
Yungn's Avatar
Yungn
Did you have any other problems? My car is not wanting to go into reverse...?
To *Help Needed* Speedometer & Skipshift not working.
