Expert tuner help needed
Old Apr 14, 2007 | 02:02 PM
rkort's Avatar
rkort
Default Expert tuner help needed
I am thinking about, removing the codes and programs that run the smog air pump and all that stuff, I don’t want to remove the hardware in case someday I may need to replace it. right now I don’t need them, I have had the ck light on for a year, have try clean out the valve. I don’t have the tools or the smart to figure it out. So a tuner friend say that we could deprogram it and remove the codes, can this be done, without any other problems
Thanks for the help
Old Apr 14, 2007 | 03:09 PM
Black02SS's Avatar
Black02SS
Yup Sure can. We do it all the time here if requested.
Old Apr 15, 2007 | 10:21 AM
rkort's Avatar
rkort
still looking for guidance
Old Apr 15, 2007 | 10:55 AM
Black02SS's Avatar
Black02SS
What type of guidance are you needing?
Old Apr 15, 2007 | 03:40 PM
rkort's Avatar
rkort
i guess my concern is that we will be able to add back the codes and program, when needed, also that i will not interfere with any other system in the car. i was also hoping to hear from otheer who have done this how how there experience has been.
thanks
Old Apr 16, 2007 | 07:47 AM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
After header install I decided to eliminate the A.I.R. system--So I went to the tables and disabled all the appropriate things there--then went over to the diagnostics reporting and turned off all the matching MIL lights and set the matching DTC reporting to "not reported"
However --------my AIR pump continued to turn on & off !!!!! For the life of me I can see no valid reason why it would still turn on---SO I then un-plugged the connector at the pump itself under the driver's side front fender and it finally quit working--and no codes !!!
Old Apr 16, 2007 | 08:30 AM
rkort's Avatar
rkort
thanks, this is what i was looking for, so i quess you can disable the code, so some reason i though you had to erase them or remove the hold program
again thanks
Old Apr 16, 2007 | 09:06 PM
rkort's Avatar
rkort
anymore
Old Apr 16, 2007 | 09:17 PM
Black02SS's Avatar
Black02SS
anymore
What else are you after? The above posts answer your question clearly.
To Expert tuner help needed
