Cleaning MAF
Old Apr 14, 2007 | 08:18 PM
crazyE's Avatar
crazyE
Default Cleaning MAF
How do I clean the MAF on my '99 coupe?
Old Apr 14, 2007 | 08:40 PM
FRCTony's Avatar
FRCTony
Remove it and spray the inside of it with MAF cleaner or electronic component cleaner. Allow to dry or blow it out with air.
Old Apr 14, 2007 | 08:45 PM
crazyE's Avatar
crazyE
Thanks....
Old Apr 14, 2007 | 10:08 PM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
i wouldn't go crazy with the air blowing, those wires in there are pretty delicate.
Old Apr 15, 2007 | 01:31 AM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
CRC makes a specific MAF cleaner... just follow the directions.
Old Apr 15, 2007 | 03:50 AM
2blklt4's Avatar
2blklt4
i used brake cleaner for mine
Old Apr 15, 2007 | 07:14 AM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
That's what I used. Mine was rather dirty, and cleaned up nice. Im not sure it made any performance differance
Old Apr 15, 2007 | 09:58 AM
rws.1's Avatar
rws.1
Aerosol throttlebody cleaner or brake cleaner
Old Apr 15, 2007 | 02:45 PM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
Remove it and spray the inside of it with MAF cleaner or electronic component cleaner. ....
that is what you want to use, any thing else is to harsh and the harsher solvents may damage the wires.
Old Apr 15, 2007 | 03:43 PM
87SAM's Avatar
87SAM
The manual specifically says not to let the sensing elements come in contact with any cleaning solvents or lubricants. So, I would not use anything unless specifically made for MAFs.
Old Apr 15, 2007 | 03:54 PM
SteveDoten's Avatar
SteveDoten
never sprayed the maf with anything, just clean the bars, they accumulate a lot of grime, use common sense around the wires
Old Apr 15, 2007 | 05:54 PM
phils C5 vette
The CRC MAF cleaner is made specifically for cleaning the MAF.
Just dont drown it. Seemed to work well. I cleaned both my screened and unscreened unit with it, though it didnt seem to do anything.
Old Apr 24, 2007 | 05:33 PM
va-c5's Avatar
va-c5
if i understand this correctly the MAF must be removed from the car or can it be cleaned while still installed? thanks for any help....
Old Apr 24, 2007 | 10:54 PM
fixvet's Avatar
fixvet
I just used CRC MAF cleaner on my '99 Blazer and my mileage jumped up and my performance is noticeably better! It was quick sluggish after I reoiled my KN airfilter with a little bit too much oil. FWIW, that only needs a wee bit of oil to work properly. I would never use brake cleaner on a throttle body or anything electronic.
Remove the MAF to clean it gently.
Good luck,
Old Apr 24, 2007 | 11:00 PM
IFLUBYU's Avatar
IFLUBYU
First rule, if it ain't broke, don't fix it. I know thats not what you are asking, but I've seen alot of heartache on here from people mussing with the maf. Just sayin', if you don't have a specific reason for doing it, I'd rethink messing with it. Good Luck!
Old Apr 25, 2007 | 12:26 AM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
Just changed out my stock airbox lid for the Zo6 lind, K&N filter etc. While I was at it I cleaned the MAF w/ CRC Maf cleaner...not just the wires but the housing as well. I also took off the air bridge and installed the "do nothing" smooth coupler to the TB. TB was clean and dry,,,not bad for and LS1 with 49K on the clock. All I can say in the end is that the inhale work described above and the Corsa's I installed last month came together to make a seat of the pants dif on throttle response. Took 2/10ths of 0-60 combined,,,,,FFFFFUUUUUNNNN
To Cleaning MAF
