Air leak on drivers window
Old Apr 14, 2007 | 08:57 PM
DBLX's Avatar
DBLX
Default Air leak on drivers window
Is that normal? Is there an adjustment to stop or minmize air leaks? 80 + mph and cross winds will cause an air leak on my drivers window. Also, when I put the window up, I get an air exhaust sound, like I'm letting air out... right when the window touches the seal.
TIA,
MJ
Old Apr 14, 2007 | 10:03 PM
kevin40zx's Avatar
kevin40zx
There are adjustments to tilt the window in and out. One is behind the reflector on the door panel. The other is under a rubber cap on the underside of the door.
Old Apr 14, 2007 | 10:31 PM
DBLX's Avatar
DBLX
Default Window
Should I adjust both, or which one should I adjust first?
TIA,
MJ
Old Apr 14, 2007 | 10:45 PM
UstaB-GS549's Avatar
UstaB-GS549
I did tip-in adjustment on mine so the door would latch without slamming it shut. There were a bunch of rubber plugs under the door edge. You need a Torx socket to turn the male Torx head on the adjustment screws. I fiddled with it until it sealed nicely without door slamming and no air leaks (tested to about 145 MPH). If the glass is pushed too high it will hit the hard plastic thing at the top of the door opening. It's not difficult, but just time consuming.
Old Apr 15, 2007 | 01:29 AM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
http://www.theredlion.us/TipIn.htm
Old Apr 15, 2007 | 02:03 AM
lordbones's Avatar
lordbones
Originally Posted by tstar
Thanks for the link!! I have suffered with my passenger window at 100mph. Annoying for sure & this step by step rocks!
Old Apr 15, 2007 | 02:05 AM
tstar's Avatar
tstar
Anytime !!!!!
Old Apr 16, 2007 | 06:31 PM
DBLX's Avatar
DBLX
Default Whew!
Double thanks for that!
Old Apr 16, 2007 | 07:15 PM
Bluefire's Avatar
Bluefire
If you have a removable targa top be sure that the last time you put in on you did not pinch the windows. Don't ask how I know.
To Air leak on drivers window
