408 motor mount clearance issue
Old Apr 14, 2007 | 09:38 PM
KS Rebuilder's Avatar
KS Rebuilder
Default 408 motor mount clearance issue
The pass side of iron block has a boss in the way of bolting up the motor mount. Do you take material off of the mount or block?
Old Apr 14, 2007 | 09:54 PM
Randy@DRM's Avatar
0Randy@DRM
Former Vendor
Take it off the mount.
Randy
Old Apr 14, 2007 | 10:33 PM
KS Rebuilder
Thanks, that's great-much easier.
Old Apr 14, 2007 | 10:50 PM
97Rob's Avatar
97Rob
My engine builder cut the block w/ a side grinder. I would not want to alter the mount. If I recall it was a threaded nipple on the side of the block that had to be cut in half.
Old Apr 14, 2007 | 11:35 PM
KS Rebuilder
That is the casting that is in my way. I didn't think it was anything that I would be using as it is behind part of the motor mount.
Old Apr 15, 2007 | 01:46 AM
bayarea's Avatar
bayarea
wait a minute im gonna be installing a 408 in my car and i wasnt aware of this issue. can i have my engine builder modify this??
Old Apr 15, 2007 | 09:48 AM
Bob K's Avatar
Bob K
St. Jude Donor '11-'25
Default It's simple!
I used a hacksaw to cut the boss off. It's easy to get at with the motor on a stand. I did not cut the mount
Bob K.
Old Apr 15, 2007 | 12:19 PM
bayarea's Avatar
bayarea
can some one post pics of this please
Old Apr 15, 2007 | 03:04 PM
KS Rebuilder
Hope this helps (circled in red). Ken
Old Apr 15, 2007 | 04:35 PM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
Just notch the mount. You dont need the boss for anything. Alot of guys have it machined down when they machine the motor. But if the motor is already built, I would take it off of the mount itself.
My mount is notched, and with over 850rwtq, if ANYTHING was to go wrong I would see it. I inspected it off the motor last week and didnt see one fracture or deformation at all.
Old Apr 15, 2007 | 07:03 PM
DOG-BOY's Avatar
DOG-BOY
When I Installed My 408 We Used A Sidegrinder On The Block. Evetrything Worked Out Great.
Old Apr 16, 2007 | 04:45 PM
LightFighter_GXP's Avatar
LightFighter_GXP
looks like you can do both
your choice!!
Old Apr 17, 2007 | 12:43 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Same thing has to be done on LS2 blocks to make them fit.
Old Apr 17, 2007 | 03:03 PM
kromberg's Avatar
kromberg
I ground down the block also on mine
Keith
To 408 motor mount clearance issue
