C5 Z06 Shifter Question
Old Apr 15, 2007 | 09:46 AM
tmoneyr007's Avatar
tmoneyr007
Default C5 Z06 Shifter Question
Besides the stock shifter what is the next shifter that provides light/medium shifts with positive engagement?
I like shifters that you KNOW when you're putting it in gear it is "clicking" in the proper gear. Not something you have to man handle to shift gears.
Also I like the shape of the delrin shifter ***** but do they transfer significantly more noise/vibration into the cabin?
TIA
Old Apr 15, 2007 | 12:40 PM
hattitude's Avatar
hattitude
Alot of people, myself included, like the C6 Z06 shifter and ****. Do a search and you will see alot of good feedback. Seems to be much better than stock C5, but not has stiff as most aftermarket.
You can get everything for about $200 from Gene Culley at gmpartshouse.
Old Apr 16, 2007 | 12:00 AM
JLP's Avatar
JLP
I would like to add a question if it is not intruding. Has any one used a delrin **** on the CZ6 shifter? If so what do you think and does anyone have a photo?
Thanks Jim
Old Apr 16, 2007 | 09:24 AM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
The C6 shifter is nothing radical. It's just a nice smooth change from the C5 shifter. I enjoy it.
Old Apr 16, 2007 | 11:39 AM
Independent1's Avatar
Independent1
St. Jude Donor '08
My brother and I just installed a Hurst shifter in my 99 FRC. It's a big improvement over the stock unit. Shorter throw, and the system is designed so that when you take it out of gear 3rd and 4th are straight up or back. So when you want 1st or second you just pull the shifter toward you, and push away for 5th and 6th.
The **** on the shifter is a ball with a non-slip surface.
Might want to check it out. A lot of people have installed these and as far as I can tell like them a lot.
To C5 Z06 Shifter Question
