factory stereo problem?
Old Oct 16, 2001 | 06:42 PM
fmp310's Avatar
fmp310
4th Gear
Default factory stereo problem?
I have a 99 C5 coupe with the factory Bose stereo system. The two rear speakers in the car are not working and i can not seem to figure out why. the front speakers and the head unit work perfectly. I checked the fuse in the passanger floor board under neith the dash and they were ok. If anyone has any ideas or the solution please help me out. Thanks!
Old Oct 16, 2001 | 08:19 PM
THENAKEDi's Avatar
THENAKEDi
Default Re: factory stereo problem? (fmp310)
This may be a bit remedial, but check to see that the fade setting for the speakers is not set to the fronts only. I believe that there is a detente position in the center of the dial travel that balances the speakers front to back. If that is not it, the speakers are probably shorting out some where.
Good Luck!
